Question about Toshiba Satellite Pro 4600 Notebook
My C Doesnt Work
Hiya what i basically is my c key doesnt work im only gettin c up now because im using on screen keyboard every time i press it makes a loud noise what sounds like a horn or lyk that noise when you first boot up a computer and i havent spilled anything on my keyboard it just happened randomly, and also i have noticed whenever i hold down any key lets say for example the backspace button it only deletes one word where as before my c key stopped working it used to delete till i let go of the key i dont know if that helps thanks.
  • 2,229 Answers
What you need is a new keyboard. Remember--they are basically anelectronic part (in this case a pressure-sensitive part) and theysometimes fail.
You can get a replacement keyboard from Toshiba or use a place like National Parts Depot.
You can reach them at
http://www.nationalparts.com/load.aspx?file=home.npd
Posted on Apr 22, 2009
Yamaha DGX 640 - keys make odd sound
I don't think that is correctable; if it is under warranty, have it repaired or replaced. The yamaha keyboards are great when they work partly because they use sampled sounds; getting extra sounds indicates a bad chip.
May 07, 2017 | Yamaha DGX-640 Walnut 88-Key Keyboard...
When loading very unpleasant noise than when im typing in the search window /////////////////// this symbol appearer what can it be?
Loud repeating beeps?
Indicative of a stuck key on your keyboard. Try seeing if the keys all "bounce back" after being pressed. If they stick, get a can of compressed air and gently blow it under the keys. If that fails, try with an external keyboard, see if that works, if it does, then you may need to have the laptop dismantled to clean/ replace the keyboard
Jan 02, 2011 | Toshiba Satellite A65-S126 Notebook
How do I lock my keyboard while a program is running?
well you can do this by using the filter keys ..follow the steps below to get your job done:
To lock keyboard with filterkeys ->activate sticky keys by pressing the shift key 5 times.
-> Go to settings and click the radio button 'use filter keys' this locks the keyboard and gives nifty little sounds all except the taskbar button if keyboard has one
->. easily unlock by double clicking little clock emblem in the bottom right hand corner of screen and deselecting use filter keys. Make sure you hit 'apply'
good luck ....i'm sure this works
Apr 08, 2010 | Microsoft Windows Vista Home Basic for PC
Hp pavilion dv 6000 keyboard not responding.Some of the keys will not respond at all. I checked the drivers and tried to update, but says most current installed. It has been doing this for about 6 months....
You need to check in the BIOS if the keys when typed does make beeping noise. Set BIOS defaults.
If the keys are still not working than boot the sys to the recovery manager and press ctrl+d to open the CMD box and test the key board there.
Boot the sys 3 times to BIOS and set BIOS defaults,
If it doesnt work try the latest update and drivers for the sys. If it doesnt work that means the keyboard needs to be repaired
Feb 08, 2010 | HP Pavilion dv6000z Notebook
The g and h keys don't function
Hello
Still? Was this the problem before? I have seen viruses that effect the keys. Download and run AVGFREE, MALWARE BYTES, and SUPERANTISPYWARE. Once these ae run, now how is the keyboard? If still a problem goto START, Run and type MSCONFIG. Once this is on the screen then select Disgnostic Startup. Save and Reboot. Only the basic OS will load. If the keys still don't work then it can only be the KB, KB connector, or mother board.
Sep 24, 2009 | HP Pavilion dv7-1130us laptop
Hi. Heres my problem. Ive been using a microsoft
Uninstalled it and reinstalled using the cd software installation.
Aug 25, 2009 | Logitech Keyboard & Mouse
The on screen keyboard doesnt work
i am not a master with the psp online mode but is everything connected properly if not im not sure what you can do
check if the keyboard is defective or maybe has a glitch
May 24, 2009 | Video Game Consoles & Games
Shift key not working
try to use virtual keyboard in start/allprograms/accessories/accessibility/on screen keyboard. And press shift. If that problem still occur when you use on screen keyboard (osk), unplug your keyboard, and try to use osk again. If that's still occur, surely you got virus or setting error
Apr 19, 2009 | Acer 2581168-0001 Keyboard
Keys doesnt work
ok..... firstly check to make sure the "NUM LOCK" is off!!! if no joy get a usb keyboard and restart the pc with keyboard plugged in, hopefully if the usb controllers are enabled in the bios you will be able use the usb keyboard and enter your password, use it until you resolve the issue
Nov 14, 2008 | Acer Aspire 4520-5582 Notebook
Key 4 doesnt work
Could be a bad keyboard. Should have a technician look at it.
Jun 10, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
