Question about Garmin GPSMAP 76 GPS Receiver
While down loading maps the 76CSX just quit. The batteries are good. When I turn on the GPS it starts then fads away like there is no power, yet I have tryed 2 sets of new batteries.
    Sergeant:
    Champion:
  • 258 Answers
It sounds like a corrupted upload. Reset the unit and retry the upload.
Usually reset is done by pushing page and enter while powering up
Posted on Apr 22, 2009
My Garmin GPSmap 76CSx will begin to start up, but as soon as you release the power button the screen fades away.
This problem can occur when the map file is corrupted or can't be read. Try putting your sd card in a reader and deleting the GMAPSUPP file (in the GARMIN folder) and fitting it back in your device. Then reload the map from Mapsource onto your handheld.
Jan 14, 2013 | Garmin GPS
My gpsmap76csx shuts off on its own, and i've changed batteries
use usb data cable to turn the power on, if power is stable then probably something wrong with the batteries compartment.
May 23, 2011 | Garmin GPSMAP 76CSx Handheld GPS GPS...
76csx I CAN'T ACCES THE MAPS ON THE GPS OR THE CARD
Features on the phone device makes compatibility to media attainable among several innovative functionalities. The phone in question least has an extensive capacity to display the entire global mapping program. For example, multimedia resources either as maps, picture grams require an expansive device components to capture display for experiences. The mobile phone in question as manufactures default only provides telecommunication resources with feature observation of media impressions. Acquiring an alternate device that has an extensive expectation would provide the requested impressions. For example, the entire global position device would provide experiences as manufacturers default. Also, computers either as desktop or notebooks provide the entire experience of telephony among several features of multimedia impressions similar to global position system programs. Computers however are multifunction's devices, also versatile that captures displays and manipulates resources.
Feb 25, 2011 | Garmin GPSMAP 76CSx Handheld GPS GPS...
I cant uploaud waypoints to gpsmap 76csx
Try reloading the software, then load the program, then attach the GPS.... Should start communicating at this point. Make sure the cable is seated correctly....
Feb 14, 2010 | Garmin GPSMAP 76CSx Handheld GPS GPS...
My Garmin GPSmap 76CSx was working just fine. After leaving it unused for a couple months with a pair of alkaline batteries installed, I tried to turn it on. It would not come on. I checked the battery...
Try connecting it to USB and powering it up, to confirm that unit still works overall. You probably damaged battery connectors. Check if you can clean the connectors better, otherwise you may need to do some soldering to fix them, by yourself or n a repair shop. Check with Garmin if they have suggestions: a leaking battery should not disable a GPS.
Dec 10, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
I have a Garmin 76CSx that freezes on start-up screen, no buttons have any effect. Only way to switch off is to pull batteries out.
I had the same thing. Seemed to be a faulty SANDISK 2GB MicroSD card. When I pulled it out, the unit worked again.
Sep 30, 2009 | Garmin GPSMAP 76CSx GPS Receiver
Problem downloading maps to my 76csx
With unit off, press and hold ENTER and PAGE while powering on to perform a master reset.
Doing a master reset will erase and data in the device and restore it to factory defaults. So if you have any waypoints/tracks/routes you may want to back them up first.
You may want to update your mapsoure software first and see if that helps the issue. If not reinstall the software.
oh and double check your micro SD card to make sure its not damaged and is inserted all the way in.
Jan 18, 2009 | Garmin GPSMAP 76 GPS Receiver
MAP 76 locks up in normal mode after acquiring and starting to track, three to four minutes. Screen goes blank except for vertical stripe, no keys work. Have to pull batteries to turn off. Unit works...
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. Just so you'll know, I also did a software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS.
What you said does make sense. When you have your unit in simulator mode, the GPS receiver is turned off, so it is not receiving signals from the satellites. The strange signal from the WAAS satellite must be what has been messing things up. Good Luck!
Sep 26, 2008 | Garmin GPS Map 76 GPS Receiver
Topo maps a mess of meaningless lines
Sorry for late reply. You need to select an area on your topo map prior to downloading it. For example, if you plan to go to Algonquin Bice Lake (access point 4), then you need to select the map around the area (starting from) Kearney upto the Magnetawan Lake and beyond. Mark waypoints from the put-in to the campsite on Bice Lake (best to compare of the topo and Algonquin canoeing map). Then you can click Transfer, click Send to Device (GPS 76cs should appear) to download it. On the GPS, enter the Find Waypoint button and you should be able to see those waypoints. Good luck for your next trip.
Aug 03, 2008 | Garmin GPS 76 GPS Receiver
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Garmin GPSMAP 76 GPS Receiver Logo
188 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
