Cannot connect to wizard
I have set up a belkin Micradigital 802.11g wireless ADSL router all lights are on and after speaking to tiscali and the router supplier i know that all connections are good but when i try to open the wizard in windows xp it will not open i keep get the you are not connected to the internet page (Work off line is unchecked) Regards Lesley
  • 54 Answers
So first go to file menu and click on work offline and then try if it is not working so create new connection ......
Posted on Jul 24, 2009
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Belkin Wireless G Plus MIMO router - connectivity problem
Connect one computer directly to the DSL modem using an Ethernet cable. If your DSL service includes a static IP address, then you will need to change the TCP/IP settings on your computer to connect directly to the DSL modem. that the router or other device on your network . For these you need to follow thse steps.
Belkin router blinking orange FIX belkin router amber light Issue
This may help you.
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
ADSL wireless router setup..
I am not sure if its the same config instruction with linksys modems...but usually you can configure it using the setup wizard or manually.
The setup wizard can be found in the installation CD when you bought the modem/router. just insert the CD and follow the instructions given at the screen.
For manual configuration...open your internet browser (IE or firefox) then type http://192.168.1.1 (or check the manual for the correct local ip of your modem) you will see the configuration page in the browser in were you will put the username, password, PPPOA, VPI...etc.
reply back if you need further info. hope this helps.
Feb 04, 2009 | D-Link DI 514 Wireless Router (DI-514)
ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
Sep 03, 2008 | Computers & Internet
Error 106
the ipaddress of the router may not be 192.168.1.1 it should say somewhere on the router or the documentation
if you are suing DHCP to allocate the IP address, and the router is set as a DHCP server you should be able to see the ipaddress using whatever tools Apple give on settign up networks.
I think there is possibly something wrong with your telephone line setup check that no phone is connected unless its through a adsl filter, or you have an adsl socket on the master socket in the house. The fact that you are not getting the online light to light up suggests to me that the router isn't talking ADSL network. consider removing ALL phones temporarily and see if that helps...
you should be able to PING an IP Address, again I don't know how youd do that on a MAC, hate 'em personally.
usually all you need to know are the IP address of the gateway (the router). set the DNS to the same IP address, unless Tiscali advise otherwise
the ADSL filters should only remove the hissing noise on the telephone line, so after plugging in the filter the phone should work as normal..
Apr 29, 2008 | SMC EZ Connect Wireless Networking Starter...
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Oct 20, 2007 | Belkin (F5D7633UK4A) Wireless Router
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
