Question about Acer Aspire 5315 Notebook
Acer Aspire 5315 m550 2.0Ghz Will Not Power Up at All
I have replaced nearly every thing but the DC connector, and the motherboard on this item and it is a no go, no power. Is there any other you could think of that may help it does not have a screen inverter plug in at the moment could that cause it not to power up in this process of elimination?
  • 4 Answers
Had the same problem myself, the dc connector gets corroded, the metal strip down the side inside the dc connector. over time it needs bending back towards the center pin. clean off the connector inside with something. thats what i did ant the customer is happy as anything
Posted on Mar 11, 2011
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
Jun 02, 2014 | Acer Aspire 5315 Notebook
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Changed the DC adapter plug it in orange light Problem with the Acer Aspire 5500 5532 5535 Laptop Computer (AS55702609RTL) PC Notebook changed the DC adapter plug it in orange light comes on charging I try...
If after the replacing the AC adapter the problem still persists , the power board on the motherboard has gone bad. The same can be repaired, but would require you to take the system in for repairs. if the system is under warranty then the best thing to do is get the motherboard replaced.
Thanks
proton
Nov 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
We just bought this acer aspire 5315 lap top brand new charger but battery still wont hold charge even plugged into the wall can anyone help please its for my kids to play?????????????? i have a gateway...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 07, 2010 | Acer Aspire 5315 Notebook
The battery works fine and so does the ac adapter what is gone bad
if it's no power it's probably the motherboard. Possibly the dc cable if the power connector is not on the mother board.
Feb 21, 2010 | Acer Aspire 5315 Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
Acer laptop 5315. While using the laptop it just
this laptop is cleverly designed, it is most probably the daughter board. this is where you connect you ac adapter. the daughter board or power board, eliminate the need for you to replace the whole motherboard when the connector is damaged. all you need to do is replace the power board. if this does not fix the issue, then there is a likely hood that you need to replace the motherboard
but before you attempt the above, first check if the ac adapter is not the problem
Sep 26, 2009 | Acer Aspire 5315 Notebook
I cant find the sd card slot on my acer aspire 5315 laptop...is there one?
yeah it does .. on the left hand side near the usb ports closest to your hand .. I am using an acer aspire 5315!
Jun 11, 2009 | Acer Aspire 5315 Notebook
Acer5315 turned off on its own and now wont turn on at all
If AC adapter is working fine fosure, DC connector might be the problem. Try to plug it and push it a little UP and see if charging light will come up. If not, push it DOWN and keep an eye on charging light, then try Left, then right. If at any point light will come up, DC connector needs to be replaced or re soldered.
Mar 18, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
708 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
