Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Gold Refrigerator (GS5SHAXNLOO), I had the ice maker replaced under warranty (at the time the repair guy told me the ice makers are flawed on this model). It has been about 2 years and the ice maker just stopped working again. Any suggestions (other than buy a new part?)
    Problem Solver:
  • 6 Answers
Check the water supply and filter
Posted on Apr 26, 2009
2 Suggested Answers
SOURCE: Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
Posted on Jun 05, 2010
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our Whirlpool Gold refrigerator is not getting cold and it is defrosted. The compressor is very hot. Our ice maker stopped working about six months ago and we replaced the cellinoid but it didn't fi
your Whirlpool has lost its gas charge , you will require a refrigeration mechanic to repair or if under warranty tell them to exchange it .
May 10, 2009 | Refrigerators
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Feb 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker not getting water
It could be the water valve at rear.check water supply to valve,
if that's ok,you could change valve at rear
Nov 30, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
568 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
