Question about Microsoft Office Outlook 2003 for PC
RE: Outlook 03
When opening outlook it says every time I open it "Data File 'personal folder' did not close properly. please wait while outlook fixes this problem"
It then runs for about 3-5 minutes everytime.
How do i get rid of this?
R
  • 702 Answers
This should be a one time action, after running the PST files should be okay. If it happens repeatedly, that means the file is still corrupt, or Outlook does not close properly.
So:
- when you close Outlook make sure to wait for it to close before shutting down the computer.
- try copying the PST file(s) to a different disk/folder, delete the old ones and then copy them back to make sure the files are not corrupted.
- if required, create a new PST file, copy all content of your current PST to it and then rename the old PST. In the account settings, point mail delivery to your new PST file.
Hope this helps.
Jules
Posted on Apr 23, 2009
Outlook ost file error
Smoothly recover damaged OST file and access offline storage data with OST to PST Converter Software . This tool quickly fixes the offline corruption issues and convert to OST to PST format. By using, users can exactly recover all email items like contacts, calendars, journals, notes, tasks, junk, etc. After, safely save recovered files to PST, PDF, HTML, RTF, MSG, DBX and many formats. This program easily works on MS Exchange Server 5.0/5.5/2000/2003/2007/2010/2013/2016.
Get more detail click here :- OST to PST Converter
Sep 27, 2015 | Microsoft Office Outlook 2003 for PC
How do you import contacts
When you install Outlook 2010, it automatically converts the Personal Address Book that you used in an earlier version of Microsoft Outlook. Outlook 2010 then adds the converted data to your Outlook 2010 Contacts folder.
If Outlook 2010 does not automatically convert your Personal Address Book, you can import your Personal Address Book to Outlook 2010. To do this, follow these steps:
  1. Start Outlook 2010.
  2. Click the File menu.
  3. Click Open, and then click Import. The Import and Export Wizard opens.
  4. Click Import from another program or file, and then click Next.
  5. Click Personal Address Book, and then click Next.
  6. Click Browse, locate the Personal Address Book that you want to import, and then click OK.
    Note Earlier versions of Outlook assign a .pab file name extension to a Personal Address Book. By default, Outlook stores the Personal Address Book in the following folder: C:\Documents and Settings\username\Local Settings\Application Data\Microsoft\Outlook
  7. Click Next.
  8. Click Finish to import the Personal Address Book.
Jul 17, 2014 | Microsoft Outlook 2010
Outlook 2010 archiving to wrong user
It looks like the folders were closed after archiving.
Try opening them again by using File, Open Data File and then picking the appropriate data file.
Apr 12, 2014 | Microsoft Outlook 2010
How to open Outlook 2010 email files backed up to a CD?
You will need to import the data from the PST file back into outlook . It should go into a personal folder
After this process you can then copy the files into your email inbox or leave them in a personal folder or create a personal folder on a server mapped drive and then import email data to this folder so it gets backed up hopefully on the server. If you bak up the server..
https://support.office.com/en-us/article/Import-email-contacts-and-calendar-from-an-Outlook-pst-file-431a8e9a-f99f-4d5f-ae48-ded54b3440ac
May 24, 2017 | Microsoft Outlook 2010
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
When opening Outlook I receive the following message, this occurred after I tried to email a photo out of a photo program: "A data file did not close properly the last time it was used and is being...
1. In Outlook 2007, click the Tools menu and select Options.
2. In the Options dialog box, click the Mail Setup tab and then click the Data Files button.
3. In the Account settings window, you will see all of your personal Outlook data files listed. Here, you want to note the full path to each data file. On my system, my Outlook personal and archive folders are stored in the C:\Documents and Settings\Your Username\Local Settings\Application Data\Microsoft\Outlook folder.
4. Once you have this information, close the Account Settings dialog box and then close the Outlook Options window.
Now that you have the location of your Outlook data files, you need to check and repair them using the Microsoft Office Outlook 2007 Inbox Repair Tool-SCANPST.exe. By default, you should see SCANPST.exe in the Microsoft Office installation folder's "Office 12" subfolder. On my system, SCANPST.exe is located in C:\Program Files\Microsoft Office\Office 12. For additional information on SCANPST.exe, take a look at the Microsoft Knowledge Base article, "How to use the Inbox Repair Tools to recover e-mail messages in Outlook 2002 and Outlook 2003."
To check and repair your Outlook data files, follow these steps:
1. First, close Outlook 2007.
2. Use Windows Explorer to browse to SCANPST.exe, then double-click it.
3. When the Outlook 2007 Inbox Repair Tool opens, click Browse and navigate to the Outlook data file location that you found earlier. Note that you will need to check each file listed. On my system, I start with the file archive.pst. To check that file, you would select it in the "Select File to Scan" dialog box and then click Open.
4. Now click Start to begin the repair process.
Mar 05, 2011 | Sony Microsoft Office Standard 2007
I had to fix my outlook email withe the outlook repair tool and now all my email goes to under Lost and Found "Recovered Folder 8082" instead of my inbox. How can I get my emails to my inbox? I can't...
I can give you a professional solution but that would be very complicated for you because you should be an advance knowledge to be able to play with email delivery rules where your problem resides.
The easy solution that I recommend you is just reinstall your outlook and before you do that take backup of your emails in the form of a .pst file.
To create a backup as a pst file
(1) Open your Outlook.
(2) Go to "File" tab on the top.
(3)Select all the emails you need by Select All key Crtl+A after going into "Recovered Folder 8082" which contain your emails. If this folder is already in Personal folder then skip the step 4
(4)Copy paste from the the folder that contains the your emails to the personal folder
(5)Check the path of the Personal folder file just for reference this pst file will contain all your emails
(6)Simply just reinstall your outlook
(7)Notice that when you reinstall the outlook If you cannot find your personal folder or if the personal folder is empty do the following
(8)Go to File in your outlook on the top left
(9)Click "Data File Management" on the drop down menu
(10)In the opening window select "Data file" Tab
(11)Click "Add" and select your Personal folder
(12)Click "OK"
(13)On the opening Window select your pst file
(14)Click "OK"
(15) Click "OK" again and your Personal folder (pst file) will be added and you will be able to see all your emails
(16) All your new emails will come to the Inbox of your Outlook from now on
Good Luck!
Oct 10, 2010 | Microsoft Computers & Internet
Personal Data File did not close properly
Hope this solves it for you! Here's the official word from Microsoft:
If you receive one or more of these error messages, you may experience performance issues until Outlook finishes the reconciliation process for the .ost file or for the .pst file. The following gear icon is displayed in the status bar while Outlook checks the data file in the background: Collapse this imageExpand this imageol2007gearicon.jpg When this icon disappears, the .pst file or the .ost file is reconciled. If you exit Outlook while the gear icon is present, reconciliation must restart the next time that you run Outlook. We recommend that you leave Outlook running until the gear icon disappears before you exit Outlook.
An incorrectly shut down .ost file or .pst file may occur for one of the following reasons:
  • Antivirus scanning of the file
  • Forced Microsoft Windows shutdown before the Outlook.exe process shuts down completely
  • Outlook add-ins
If you see this issue frequently, and you have to exit Outlook shortly before you shut down your computer, it may be better to shut down Windows while Outlook is still running. We recommend that you do this instead of exiting Outlook and then shutting down Windows shortly after that.
Dec 26, 2008 | Microsoft Office Outlook 2007: Windows
Outlook 2007 slow on closing and crashes on open
Your computer might be using caching. Can you tell me how much RAM you have on your computer? If you have 2GB of RAM i would recommend disabling the caching. This slows down the system quiet a bit (since it uses miliseconds instead of nanoseconds). Your computer is as fast as the slowest component.  I would also suggest defragging the drive.
Oct 14, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Outlook 2003 for PC Logo
83 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
