Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
E74
By big tex on Sep 23, 2007
attempted to eeboot system,unplugged hardrive,problem unresolved after multiple attempts
Same Problem
Apr 23, 2009
-   same prob the guy that fixes it sucks it breaks bout a week after he so called fixes it so yeh am gettin a xbox 360 pro... -   Guest
Mar 23, 2009
-   i have had the e74 xbox 360 problem for a while and i have tried everything everybody has told me to and still havint fixed it-   Guest
Feb 22, 2009
-   Every time I turn on xbox one red light comes on, on screen I get system error.and lots of different langauges and E 74 on bottom of screen. -   shane74
Feb 08, 2009
-   it strted goin fuzzy, like white blotches, and then the red circle came up, so i turned it on and off but it didnt work, it came up with system e74 error,, with loads of different languages ?-   badboi991
Feb 06, 2009
-   I have the same problem with one red line and E74 error message-   Guest
Best Solution
posted on Jun 03, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
There is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In rare cases it is a problem with the GPU.
Solution #2
posted on Sep 25, 2007
Helpful)
McloveN
Rank: Master
Rating: 77%, 36 votes
E74: AV cable error? There is a problem with the AV cable, try using a different AV cable. (this could also be a problem with the internal AV encoder chip)
Was this helpful?
Yes
No
Solution #3
posted on Feb 03, 2009
Helpful)
sfreeman84
Rank: Apprentice
Rating: 79%, 4 votes
http://www.associatedcontent.com/article/1380695/how_to_fix_an_xbox_360_with_e74_error.html?cat=19
I wrote this article and it has allowed my xbox 360 to be running for over a month now. Give it a try!
Was this helpful?
Yes
No
Solution #4
posted on Feb 02, 2009
Helpful)
ACMH Scott
Rank: Master
Rating: 79%, 3 votes
okay i had this problem..... it is definately a problem with the AV part of the console, firist ask a friend if you can lend is AV cable n if it works you need a new one or just buy one from cex if it does not you need to send it to micosoft dont try tooverheat your xbox it jst makes it worse
Was this helpful?
Yes
No
Solution #5
posted on May 17, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
dordy kaka roka chavy
Solution #6
posted on Feb 25, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
sheeet
Solution #7
posted on Apr 30, 2009
Not Rated)
sadfgh
Rank: Master
Rating: 78%, 29 votes
Try this link . . . www.microsoft.com/Xbox360Console
To find your best solution.
Was this helpful?
Yes
No
Solution #8
posted on Sep 27, 2008
Not Rated)
djskillz275
Rank: Apprentice
Rating: 0%, 0 votes
3 red lights
Was this helpful?
Yes
No
Solution #9
posted on May 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
A way to fix it is to overheat your consol, get loads of towels or somit, and cover all sides of the consol and leave it to overheat, turn it off when ti doesn and it will work. 100% proven.
Solution #10
posted on May 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
there is no hope to fix it a have the same problem and no way to fix it so you have to send it to MS or buy a new one like me
Solution #11
posted on Feb 24, 2008
Not Rated)
aa22
Rank: Apprentice
Rating: 93%, 8 votes
send it to MICROSOFT
Was this helpful?
Yes
No
Solution #12
posted on Jan 08, 2008
Not Rated)
bobntina
Rank: Master
Rating: 85%, 17 votes
E74 for XBOX 360 is a hardware failure. Unplug all controllers, hard drives, memory card(s). Unplug and reseat the power cable and the A/V cable. Check the power supply to see that color led lights up when you turn the console on. If it is red or orange it is an issue with the power supply (either overheating or too much/too little power. If you are plugging the power supply into a cheap surge protector plug it directly into the wall. If none of these suggestions work then you need to contact Microsoft.
Was this helpful?
Yes
No
Solution #13
posted on Nov 30, 2007
Not Rated)
allergicmmm
Rank: Apprentice
Rating: 62%, 2 votes
go to youtube.com and task how to fix e74... they will show u
Was this helpful?
Yes
No
Solution #14
posted on Nov 27, 2007
Not Rated)
Game Boy
Rank: Apprentice
Rating: 89%, 25 votes
i have a problem with my xbox it has a code saying " E 74" whats that supposed to mean do i have to enter it on something or what, I've had my Xbox ever since the thing came out in stores i care for it sooooooooo much, is the end of it, no it can't be. How do i fix this problem please im dying to play it, if i dont play it soon i might go CRAZY. please someone, help me.
Was this helpful?
Yes
No
Solution #15
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i went and bought a new av cable i still get e74 occasionally it works gahh
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
what are the wep64 codes and where can i find them cant get connected to my home hub
Answer
it wont turn on i tryed i every solution posssible cleaned it checked if everything was pluged in
Answer
i have 3 red lights flashing and my disk tray gets stuck
Answer
my xbox 360 has an red light on and it keeps freezing and wont play any game
Answer
the picture is not appearing on the television
27 Other Users Have The Same Problem - Continued
Comment by karlkev, posted on Feb 03, 2009
e74 error came up along with the system error screen in multiple languages. Tried the cable unplug solution to no effect. Have an e-mail in to xbox now.
Comment by Guest, posted on Jan 24, 2009
My xbox elite has one red light and gives the code e74. I called xbox technical support and they had me do some troubleshooting. Seems that my 360 will or cannot read any hard drives. Even when I remove a hard drive it will not go to a green light.
Comment by www_dan_garc, posted on Jan 16, 2009
one red light and E74 . how too fix ?
Comment by jandjs01, posted on Jan 12, 2009
i have one red flashing light and error e74 i have tryed unplugging everything and restarting it but still no good
Comment by Guest, posted on Jan 11, 2009
e74
Comment by jradizzle, posted on Jan 02, 2009
yeah i got the same problem. i've tried to fix it from online guides but nothing works. some help, S.O.S.
Comment by skydiver5, posted on Dec 29, 2008
when i turn on the xbox 360 it keeps saying e74 error code
Comment by hank12345678, posted on Dec 07, 2008
i got the same thing im trying to send it in to get it fix. i stll have warrenty if u need any help msg me @ hank.p@live.com
Comment by joshcarr, posted on Aug 09, 2008
a red light came up on bottom right corner and evry time i turn the xbox on it says E 74 along the bottom of the screen what do i do??? i restarted un-clicked every accesory what now?
Comment by Guest, posted on Jul 26, 2008
light is red in right bottom corner
Comment by Guest, posted on Jul 17, 2008
I was playing call of duty 4 online when my screen went weird....i tried restarting my xbox but when i tried to reboot it the bottom right light was red and the E74 message was on the screen what do i do
Comment by deadmenwalki, posted on Jul 15, 2008
red light is showing and giving me a error called e74
Comment by impaledale, posted on Jun 19, 2008
E 74 error
Comment by sick-n-tired, posted on Jun 14, 2008
color became distorted turned system off then back on e 74 error message and no longer works
Comment by Cougarez, posted on Feb 16, 2008
I was playing on xbox live, and my whole screen turned green. When i attempted to reboot my xbox, the E 74 error came up. I tried everything in the book to fix it but it never worked.
Comment by fixedit765, posted on Dec 25, 2007
I have done what the Microsoft Knowledge Base says many times and it still has the error. What exactly will solve the problem?
Comment by youngboi, posted on Nov 26, 2007
null
  1. some black screen with E 74 and red flashing light
Comment by camkong, posted on Nov 12, 2007
i have the same problem about the coloured dashes while playin games and dvds and thenit just went , ploop and it didnt work no more
Comment by pjajmom, posted on Nov 12, 2007
My system was working yesterday but I was getting these vertical black dotty lines while trying to play and green vertical lines when it was going from one game screen to the next. But when it was on the menu screens it acted totally fine. Now today I have one flashing light with error code E74. Of course they say my warrenty is expired and I have to pay $99. But if you do that they only give you one month warrenty after that. Crazy!
Help!
Becky
Comment by Guest, posted on Nov 11, 2007
Hey, I just started getting that error code (74), out of the blue, on this Sunday morning. I've tried everything on the Xbox support site, detach the hard drive, remove all cables and reatach, etc., but nothing works. Any suggestions, anyone?
Comment by p prince, posted on Nov 07, 2007
yo every time i turn on my 360 i get the E 74 code on it i turn it off about 12 times a day but it still deos it im soooooo mad any advise
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
