Canon EOS Rebel 2000 35mm SLR Camera Logo
Anonymous Posted on Oct 07, 2013
28 80 autofocus
How do I set to fully automatic?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Oct 08, 2013
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441052
Points
622693
Turn the mode dial to the green rectangle for automatic exposure. Set the autofocus switch on the lens to AF for automatic focus.
Barry Boyd
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Nov 10, 2013
Barry Boyd
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
21734
Points
135
The manual for your Canon EOS Rebel 2000 can be found here:
http://downloads.canon.com/cpr/software/camera/EOS_Rebel_2000_manual.pdf
Check out page 24 for instructions on shooting in fully automatic mode.
Hope that helps,
Bax
3helpful
3answers
Need to set to fully automatic setting
Hope that helps,
Bax
Nikon D90: Won't focus properly in automatic mode
Make sure the subject is well lit. The autofocus relies on differences in contrast to determine proper focus. Move to a well lit area or add additional light and attempt again.
Make sure the aperture ring on the lens (if that lens has one on it) is set to minimum (highest number - f22 etc.) This value it often a different color ink than the others to help speed locating it. On most Nikon & compatible lenses, when the aperture is set to minimum, the camera's main & sub command (thumb and finger) dials will control the aperture and shutter speed. When the shutter is held down 1/2 way, the aperture will open fully (to allow the most light in and speed composition) and then automatically stop down to the commanded value when fully depressed for the exposure. If you have the aperture set on the lens to something different - it may be preventing sufficent light from entering and interfere with the autofocus function.
Automatic focus not working
Which lens(es)? Do you have autofocus turned on both on the body and on the lens? What autofocus mode(s) do you have set on the camera?
I fully charged the battery and camera appears to be working but on automatic mode when I push down the button, nothing happens. Camera is fairly new.
This may happen if the autofocus cannot get a fix. Also if the exposure is out of range the camera refuses to fire.
1helpful
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Canon 40D Autofocus not working
Maybe The Button Is Broken Chek The Button If It Still does Not work Let an Axpert Chek Your camera
Buying a camera lens
Presumably you intend to use a DSLR. The automatic nature of modes relates to exposure. Lenses autofocus assuming you have turned the autofocus switch on. Switch the autofocus off if you want to manually focus. Whichever you use will not affect the modes
May 11, 2008 • Cameras
2answers
D50 autofocus
Check two switchs, one on the camera body and one on the lens. Make sure they are both set to AF. At least that is how it is on my D80
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
