Question about Creative Labs Zen Stone Plus MP3 Player
Frozen It gets stuck on pause when I turn it on and it won't register on my computer, I have tried pressing the reset button and it won't work.HELP!! @-@
Usually it takes a couple of tries before the computer will recognize it if it's frozen. Once the computer recognizes it, format it immediately and that should fix it.
Posted on May 25, 2009
PLAY/PAUSE Button issue Hi, got a problem with an CDJ 1000 MKI when i put a cd on it , and starts playing i try to press the play/pause button it will freeze and will have to reset the machine, have...
Yes, this can be caused by a faulty button or buttons, where they are stuck in the on position. The control line gets blocked by the stuck button, and won't even eject in some cases. Take it to a service centre and they should be able to resolve it while you wait, and drink their tea :)
Aug 19, 2011 | Pioneer CDJ-1000 CD Player
My phone won't start, when you press the power button it tries starting then when it gets to the windows phone screen it restarts. Please help.
PLease do a hard reset ... Here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Press Vol down for reset .
Thumps up if this works ..:-)
Aug 09, 2011 | HTC HD7 Cell Phone
Frozen player.
press the RESET button ....on the back
Mar 26, 2010 | Samsung YP-K3 MP3 Player
My ipod was put under a pile of books and now it's frozen! Help!
If you hold down the top and bottom buttons ( Think they are play / pause and the menu button down together ) for at least 5 seconds - obviously doing this when the lock slider switch is on the unlock position and it should do a hard reset and allow you to reset it.
If that does not help there are articles on the apple website which will walk you through how to reset it.
If you can do a hard reset via the menu and play / pause button ( holding them down for at least 5 to 10 seconds ) it should start to restart - when its restarting let go and it should request you to select a language and go from there.
Jun 02, 2009 | Apple iPod nano 3rd Generation
Frozen ipod
Hey i scored you these instructions on how to reset your frozen ipod. Hope its hella useful. Good luck :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Apr 23, 2009 | Apple iPod MA446LL/A MP3 Player
Frozen
First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Apr 22, 2009 | Creative Labs Zen Touch MP3 Player
Ipod nano 8gb
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Oct 21, 2008 | Apple iPod nano
Frozen ipod
You could try to reset it by doing the following:
Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on
Apr 09, 2008 | Apple iPod nano
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Creative Labs Zen Stone Plus MP3 Player Logo
166 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
