Epson projector--no "EPSON" sign-on. Shows diagonal bands of yellow and greed in venetian blind fashion. Can lightning or surge do this? What's broken? Can it be fixed?
  • wtoncre Apr 22, 2009
    Sorry, wrong category. I have an Epson LCD video projector not projection tv
  • 11,896 Answers
The problem is due to faulty color wheel, ballast, or ICs (capacitors) They all can be replaced. But they will have to be tested. Look at the color wheel to see if colors are faded or ran together. If the wheel spins, than the ballast is good. It is very common for the color wheel and capacitors to go out on these tvs.
Posted on Apr 22, 2009
  • Nate Stansfield
    Nate Stansfield Apr 22, 2009
    The video projection is set up the same way.
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
Can't get my epson 450wi to turn on shows red
What shows red? If all 3 lights are flashing red you are out of luck. If it is under warranty call Epson. If your warranty has recently expired I would still call Epson. This is a "known issue" for this model projector.
Mar 06, 2014 | Epson BRIGHTLINK 450WI Projector
My epson projector shows a non growing yellow tinge in the centre of the image. The projector is about 4 years old. EMP-TW700. I am a fairly heavy user.
From my experience, the projector bulb has most likely received a blemish of some kind from something such as accumulated dust on the front, to a fingerprint from where it has been handled by someone replacing it.
This yellow tinge then occurs when the blemish is burned onto the surface of the bulb.
In my opinion, unfortunately, you may need to get a new bulb.
Hope this helps!
Mar 03, 2011 | Epson (V13H010L32) Projector Lamp for...
Damage to equipment from power surge
yes a spike may destroyed the mov (metal oxide variastor) inside projector replace it problem will be solved spike comes in the case of storm and lightning strike apc ups are well protected from spike and surge
Mar 04, 2010 | APC Back-UPS XS900 (BX900) UPS System
My epson
the light filter on the blue lcd panel is fried due to excessive dust and heat. it's a common problem with lcd projectors if you don't keep them clean and cool. unfortunately, you'll have to replace the entire optical engine, as epson does not sell individual parts.
Nov 09, 2009 | Epson - PowerLite S1+ Multimedia Projector
How to hook up cable from the wall to epson ex30 projector
The Epson is a monitor only. It has no tuner, so no cable connections. If you have a cable box or VCR, or DVD with RCA Style Connectors (yellow, red and white) connect your cable coax to the box or VCR and then the video and audio outputs on the box or VCR to the projector and select the video mode.
May 28, 2009 | Epson Televison & Video
EPSON EMP 3000
There is an adjustment in the Video section for adjusting it to look square.
Aug 13, 2008 | Epson ELPSC07 for PowerLite Home 10,...
Yellow hallo problem
It sounds like it is related to the red filtered glass before the prism inside the projector. When this gets to hot, it will burn a spot on the glass that causes the yellow spot. I have seen in happen on alot of epson 53c projectors. This has a red filter that is easily scratched when it gets too hot. It will actually look burnt.
Dec 27, 2007 | Epson EMP-830 Multimedia Projector
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
