Low air volume coming from supply registers. Checked filter. Checked charge, 40 low/250 high Checked duct, no leaks or breaks. blower turning.
  • 3 Answers
You may also have a bad logic board that controls the blower motor (ramping up/down speed) or a hole in the duct work that is blowing the cold air elsewhere.
At the attic unit, see if you can tell if the blower sounds like it is pushing a lot of air If not, only a professional can check motor and logic control function.
Also check at your supply registers for an appropriate drop in temperature from your erturn registers (20 degree drop or so). If one supply is not getting that drop, then you may have a detached duct or hole.
Posted on May 21, 2009
    Problem Solver:
  • 19 Answers
Could possibly have a bad blower motor or on the brinks of one. check the run amps of the motor make sure its doing what it should. if not may need new bloer motor
Posted on Apr 22, 2009
I have a atwood 34,000 btu furnace that operates the way its suppossed too, except the heat that comes out of the ducts is not that hot like it should be !! What can cause this and how do I correct th
On the rating plate of the unit, where the model number and BTU rating is found should be something called recommended temp. rise. It will be a range (30-50 or 25-45, something like that) place a thermometer at the return (room temperature) air and the supply air coming out of the nearest register. The temp. difference between the 2 thermometers should fall in the recommended range. If it is in the range, it may be all its gonna give you. If your unit has a multi speed blower, set it to the LOWEST speed. This gives you maximum temperature rise.
Dec 09, 2014 | Atwood 34,000 BTU 8500 IV Furnace
Change the ac compressor
Recover all refrigerant. Remove hoses, unplug wiring, remove belt, unbolt compressor. Replace in reverse order. Change filter dryer, replace "o" rings, belt and be sure compressor has oil in it before installing it. Make all hose connection, put vacuum pump on to evacuate system. Charge with engine running through low side lines(the larger one). Check High and Low pressures. Put a thermometer in the duct inside vehicle, turn fan on highest setting and coldest setting. Should get down to about 40-42 deg.
Sep 20, 2014 | Heating & Cooling
2006 Ford Fusion Air Conditioning compressure not turning on.
Thats pretty high if the system is not running. Average pressure on the low and high side should be near outside air temp.
Normal low side is 30-40 psi and high side is 200-250 psi when the system is running and the freon charge is full.
Aug 28, 2012 | 2006 Ford Fusion
Air ciculation
It may be that you have a plugged cabin air filter, have it checked and replaced
Jul 27, 2012 | Cars & Trucks
High suction press (98psi), normal head press (140psi); full sight glass;low super heat (10 degrees);normal subcooling (13 degrees) new txv, new evaporator, new condensing unit 70 degree air from vents ...
lower fan speed.....and double check head pressure, sounds very low!!! should be around 250-275.....also make sure the return air grill is large enough.
Aug 09, 2010 | Goodman CLQ36AR49 Air Conditioner
Air conditioner is freezing up
Three most common things that cause an a/c to freeze up.
  1. Plugged/dirty filters
  2. Blower motor not running
  3. or there is a leak in you refrigerant system and you are now low on charge
Oct 07, 2009 | Heating & Cooling
LG 3phase ducted CH02 fault (internal pipe thermistor error)- every day. When it comes up the air con shuts off, and takes a few hours to clear itself. Very annoying. I notice though it comes up less if i...
have u checked your low pressure and high pressure when compressor is on. Remember the compressor has a thermal protection switch if the compressor has too much freon the A.C will work for a while turn off, then turn then off and on. Are the air filters for the evaporator clean, is the blower fan blowing the correct way. How long ago did the evaporator coil got cleaned. With a properly cleaned filter and evaporator coil you can now check for pressures. Use your ammeter and check how much the compressor is pulling and compared it to the name plate. How much tons your A.C. If you give me how much tons and low and high readings I might help you diagnose the problem. Make sure the evaporator is clean blower blowing correct way condenser cleaned and condenser fan rotating the correct way
Jul 24, 2009 | Heating & Cooling
Pressure problems
those seem to be very acceptable numbers you are stating if this is R22 running in summer temps. Im curious what pressures you are striving for?
Jul 02, 2009 | Heating & Cooling
Don't blow enough air
Here are a few things that would cause low amount of air to come out of the registers in home:
1. Something is blocking return air, like couch in from of return air register.
2. Dirty air filter. Clean or Replace!
3. Icing. Check large pipe on outside unit. If it has ice on it shut off sustem and call a qualified technician.
4. Fan speed may be wrong on blower. Put on HIGH.
5. Duct work may be apart. Check duct work and correct if needed. Note: If you have asbestos duct work do not repair. Call a qualified repair company.
I hope I have helped.
Terry
Jun 23, 2009 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
