Question about Dell 3010cn Laser Printer
How can I fix printer to print?
I'm getting Load MPF 024-969 and it won't print anything. I put a small stack of paper in but it still comes up with the code and will not print anything.
  • 3 Answers
Make sure if its an older printer your nozzles where ink is transfered isn't clogged, if its not printing it could be that. Simply use some rubbing alcohol on a cloth nd rubbed them gently, let sit so it can open it up. I have no expierence with your specific printer. Make sure ink yea you may think you have ink but computers arent always correct, 2) make sure ink is all the way in. if it saying that paper is out you may have to re-insert your installation disk, and fix any errors. I hope this helps
Posted on Apr 22, 2009
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
MPF 024-969
Is the paper pushed all the way back into the MPF?
If yes, what type/size paper is your application sending?
If you try to print the internal Printer Settings report, does it print?
This error typically means that no paper is sensed in the MPF OR that the wrong type/size paper is in the tray. (MPF settings do not match job specs)
Oct 27, 2009 | Dell 3010cn Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
What does load mpf mean
It does stand for Manual Paper Feed.
On this printer, that's on the front of the unit, above the paper trays.
Once your PC has sent a print job with the paper-select set to "Manual Paper Feed" the printer will not do anything until it's processed this job.
The easiest way to do this is to put paper into the MPF and let it print, but at some point you're going to want to fix your PC so it doesn't send MPF print jobs anymore.
To do this, open your Printer Properties and select the default paper tray instead of the Manual Feed.
Sep 25, 2009 | Dell 3010cn Laser Printer
My Dell Color Laser Printer 5110 cn won't print. It keeps saying ''Load MPF Letter'' then ''Load MPF Plain'' then ''Load MPF 020-969
it's asking for paper in the manual Paper Feeder (MPF). Somewhere in your settings you have it printing to the MPF. Check the settings in the printer prefrences, the printer itself and the software you're using.
Cheers.
Sep 23, 2009 | Dell 5100cn Laser Printer
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
A dell 3010 which prints fine from webpages etc. but refuses to print from out look and says load plain mpf 024-969 when there is paper in the machine which it was previously happy to print on.... very...
Outlook's printer options are set to load paper from the Manual Paper Feed (mpf) instead of the regular paper tray.
In outlook, select file->print and look for the printer properties button on that dialog box.
Select the paper tray you want to use (or simply uncheck "MPF" or "Manual Paper Feed") and hit OK.
Jun 14, 2009 | Dell 3010cn Laser Printer
Can't print. message load MPF won't go away
There is a print job waiting, either in the printer's memory or on your computer's memory. This print job is set to go to the Manual Paper Feed (MPF) which is accessible from the front of the printer by flipping down the little MPF door.
You can change settings for new print jobs, but once one job is submitted with "Please Print Me On The MPF" set, there's no way to change that job.
The easiest fix is to put some blank paper into the MPF and let it print out.
If it's spooled on the printer, you can turn the printer off and back on again to clear the job.
If it's spooled on your computer, you can view it by bringing up the Printer settings:
Start->Settings->Printers and Faxes
Find your 3100 and double-click on it.
Find the print job, select it and pick "Cancel" from the "Document" menu.
Mar 31, 2009 | Dell 3010cn Laser Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Dell printer 3100 cn laser
I had the dreaded 024-969 and was just able to print a test page.
I removed paper and reached inside the MPF. There's a spring-loaded lever facing upward, toward the back of the tray that the paper rests on and depresses. I toggled this up and down a dozen times.
I vacuumed out the entire tray area and then blew air into the same area by reversing the shop vac hose connection to the output hole.
Printer now prints.
Jun 11, 2008 | Dell 3100cn Laser Printer
Dell 3010cn Laser Printer Logo
728 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
