Question about Microsoft Xbox 360 Console
E74 error code
Attempted to reboot system unplugged hard drive,problem unresolved after multiple attempts
    Scholar:
  • 33 Answers
The cause of the E74 Error might be overheating of your console and for avoiding such error messages in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling the console such as cooling the machine through a pedestal fan etc. But as your Xbox already have E74 Error, You can either send your Xbox to Microsoft for repair ( just for your information Microsoft is no longer providing Extended warranty for E74 Problem), Microsoft generally takes 3-4 weeks to fix the problem. If you can't wait for a month (I know most XBox gamers can not wait without their favourite Gaming device), You can also fix E74 Problem yourself and that too within an hour without any technical knowledge. I would suggest you to check out the DIY Xbox Fix Guide for more information.
Posted on Mar 05, 2009
How to fix E74
Posted on Jan 16, 2009
I have found that the same fix for the ring of death also works on this error check utube for details on fix i have preformed this fix on 3 other customers machines with only 1 call back
Posted on Sep 25, 2007
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
Logical drive has been disabled due to possible data loss
Replace the HDD whose led is blinking in AMBER ( orange ) colour.
Mar 11, 2012 | HP Compaq ProLiant DL380 G4 Server
Hi! There are times when i open my laptop, this message appears on the screen "Window detect hard disk problem" and there's specified device mentioned this one "wdc-wd5000bevt-22aorto...
the best solution is scanning disk if there is any problem in it run scandisk from sytem tools and check for error if there would be a error it will fix
Aug 20, 2011 | Computers & Internet
Not working Code 10
Code 10 refers to a device not functioning (assume you are using a computer and windows here)
As a first attempt, unplug all the non essential items and reboot into safe mode (f8) If this works go to C drive click on properties and run the maintenance to reapir disc errors
Jan 02, 2011 | Computers & Internet
Dst error cose 1000-0146
casarrubiasl
Unfortunately the error that you getting means that there is a problem with the hard drive. So you will need to replace the drive in the system.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 10, 2010 | Dell Latitude D600 Notebook
System error, code.. E74
RROD, Send it in to microsoft for a free replacement. Xbox360 right?
Apr 19, 2010 | Microsoft Xbox Console
I have a Dell Inspiron 1525 and I am getting the error message 2000-0146
This error code is part of the DST (Disk Self Test). Unfortunately that particular error code is telling you that there are previous errors in the log. There are multiple things that can easily lead to hard drive errors.
The first thing I would do is a checkdisk. To initiate this, open My Computer. Right-Click on the C:/ drive and select Properties. Click on the tab that says Tools. And there is an option that says "check now" under Error Checking. Select both options on this tab: Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
This will likely give you a message saying it's unable to check now and will ask to do so on the next reboot. Restart your system and wait for the scan to finish. After this, check your logs and see if you're still getting the same errors.
Jun 21, 2009 | Dell Inspiron 6400 Notebook
When i turn on my xbox one red light come on an it say system error contact xbox customer support systemfehler E 74
One red light means one of the following, according to Microsoft:
This type of error will show an Error On The Screen. The Error List Is As Follows:E64 - Error: Key Not Valid Or Firmware Problem.
E65 - Error: Key Not Valid Or Firmware Problem Or Flashrom Is Not Responding.
E67 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E68 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E69 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E74 - Error: Video Cable Problem. Possible Damaged Video Cable
Depending on what error code you get, try fixing whatever the corresponding error message is, above.
Mar 19, 2009 | Microsoft Video Game Consoles & Games
Aspire 6920 Operating system not found
you have no choice but to open it up, this is to check that the hard drive works or has disslodged, pull the hard drive out and then reseat it again, reboot the laptop and see if the bios has found the hard drive, if it does try to boot into it
kind regards
Dec 22, 2008 | Acer Aspire 6920 Notebook PC
Maxtor 80GB External HD
1. I need to know the brand name , model number , or motherboard you have
2. I need to know what operating system you are using
and when you say open , in what manor do you mean open , in what way are you attempting to open the drive and with what program , so far it looks like you may need to reinstall the computers operating system from scratch , because something is dead wrong , and it looks like a file system error , as if your computer operating system is no longer able to access files properly.
I consider your situation unresolved at this time untill you can give me more information.
I'm trying to reach guru status here in order to help people like you in a far more proper manor.
together we can solve it.
shalom
Aug 05, 2008 | Maxtor Hard Drive
Microsoft Xbox 360 Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
