Speakers have no sound
I bought some new speakers and i set them up in the way the manual suggested, they say that they have power and the computer has recognised they are there, however there is no sound at all. I have checked that they are not on mute and that the computer is not. I can't work out this problem and i have lost the manual. The speakers are: Advent 2.0 interchangeable pc speakers.
    Problem Solver:
  • 8 Answers
Well firstly check all your cables, or your volume control because some people dont check if it's muted or not, if not go to start-right click my computer-props-device manager and make sure you have no yellow simple next to anything if you have you need to find the right driver for your sound card, do the same click the driver with the yellow symbol, right click, props, go to driver details and coppy the name in of the driver by ctrl c, firstly highlighting it, then paste into google and you should have you driver :)
Posted on Apr 22, 2009
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
Speakers don't work quite right
Check first to make sure impedance marked on speakers is same as original---two sets of positive and negative terminals suggests original ones were dual element speakers----
If for example original were marked 8 ohm and you put 16 or 32 ohm speakers in----volume will be greatly diminished and even distorted.
This is only a suggestion as I do not know what original speakers were or what new ones are----but the key is originals had two sets each of connections.
May 18, 2012 | 2002 Oldsmobile Alero
I just bought a speaker for my computer but i can't hear sound from two of speakers ! how can i solve it ?
if your sound is not working you can check that the plugs are in the computer correctly usally there are green and pink ends on computer speakers green indicating goes in the green slot and pink in the pink some people often gets confused and there are sometimes on new modles a blue slot that can look green in low light i would suggest checking they are plugged in correctly to the computer preferably in the back and not the front if the front option is avalible and check the appropriate drivers are installed on the computer to use the speakers
Jan 19, 2012 | Logitech X-530 Computer Speakers
Ok my new pc has 7.0 audio and I have bought the above mentioned speakers and plugged them into the back of the pc. Everything is on the power and all cables are where they should be according to logitech...
Have you configured the sound output in Control Panel / Sounds to accept the speakers as output, checked the line out volume is not set to mute and that the green cable (line out) from the speakers goes to the green socket on the mobo?
Also, have you tested speakers in another computer r laptop and your computer with a different set of speakers?
Feb 07, 2011 | Logitech LS-21 2.1 Speakers
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
I bought a sub woofer from a thrift store used and even though my existng computer speakers have a sub woofer jack, after hooking it up, it doesnt play. I bought the digital chord which fits well in the...
Different sound system use different voltages for their speakers. Look up in your computer manual what the electricial requirments are for the speakers and see if the one you bought matches.
Dec 15, 2008 | Computers & Internet
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Dynex soundcard is installed however my pc still has no sound!
Hi Sammantha78,
I had a similar problem with my computer and I went and bought new sound card and installed it and I still had no sound. I then went and bought a new set of speakers and now i got sound. I suggest you test another set of speakers on your computer to see if it’s not your Altec Lansing speakers that is not working.
Sincerely,
Agent Xiong
Apr 15, 2008 | Dynex DX-SC5.1 Sound Card
Speaker problem
Hi, Assuming that the speaker is plug in to the PC and power is also applied to the speaker - If the PC sounds comes out of the headset but not on the speakers, then the speakers are defective. Being new/recently bought, your best course of action would be to bring the unit back for replacement or at least the speakers since trying to repair it would void the warranty. Please remember to bring proof of purchase, warranty card or whatever document(s) are required for this sort of complaint. Good luck and kind regards.
Aug 20, 2007 | HP P5302M Computer Speakers
Computers & Internet Logo
David Payne
David Payne
