Question about Motorola Mobility RAZR V3
Motorola V 3
The top flip screen & bottom of phone are connected by two screws one blind another with slot. Some how I droped the blind bolt/screw. I have spare phone but not sure how to remove it. Is it press fit or is it screwed. Is it clockwise or anticlock wise. How to do it? Thanks
    Brigadier General:
  • 7,752 Answers
It is screwed and clockwise
Posted on Feb 17, 2008
Motorola w845 quantico disassembly
I have never done a w845 quantico but have done several V860 barrage phones in my time. Both of these phones have a similar design. On the barrage if you flip the screen open, on the inside of the flip there are 6 screws, undo those screws and place where you will not loose, then the top part will separate with just a little nudging (front cover from back) the earpiece in the barrage is in a small compartment and has two contacts (no screws just some adhesive) remove and replace, clip the front back together and replace screws. Most important part is to make sure you do not damage the LCD cable in the hinges of the phone.
Dec 22, 2012 | Motorola Mobility W845 Quantico
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
Jun 22, 2010 | Motorola Mobility RAZR V3
How do i replace flex cable on a razor phone can u show video
Ok..#1.take the battery out..
then youll have to remove the 2 screws that hold the modem part of the phone in.gently pryup on the modem ,on the side with out the usb charger port..slip a thin flat tipp screw driver in there and slide it towards the bottom of the phone. there are littler plastic clips carefull not to break them.then youll see where the bottom of the flex cable plugs in.unplug it.then flip the phone over,in the 4 cornors of the screen side of the flip there are tiny little rubber plugs. pop them out and undo the screws in there.near the top of the screen there is a little slot on the right side of the screen ..gently pop the cover off the screen..unplug the flex cable from the screen.and carefully remove the screen.be careful not to damage the buttons on the sides of the screen.then close the flip and turn the phone over..looking into the battery part of the phone,on the top right hand side of the hindge there is another little screw,remove that.then again turn the phone over and stick a flat tip screw driver into the open hole and pop the chrome roller out.then very carefully youll be able to seperate the 2 halfs. look on the back side of the keyboard youll see little metal tabs folded over that holds the key board in place..the keyboard and the flex cable are one piece, just revers the procedure to replace.." BE VERY CAREFUL RUNNING THE FLEX CABLE THREW THE HINGE AS IT CAN DAMAGE VERY EASLY." IF YOU NEED MORE ASSISNT CONTACT WWW.PHOENIXTEC.CA they are very helpful
May 11, 2010 | Motorola Mobility RAZR V3
Belt is broken. how do we replace it?
Well you can please follow the below steps -
1. Locate the shutoff valve for the gas line behind the dryer, and turn the valve one-quarter turn by hand until the gas supply is closed off to the appliance.
2. Unplug the electrical cord of the gas dryer from the outlet.
3. Take the lint screen out of the lint screen slot on the top of the dryer, and unfasten the screws that are inside the slot with a screwdriver.
4. Place a putty knife between the top and the front panel at both corners, and lift up to disengage the plastic clips.
5. Lift up on the dryer top, flipping it toward the back of the dryer, and lean it against the wall.
6. Locate the screws inside the top of the dryer behind the front panel, and unfasten them with a screwdriver.
7. Slide the front panel forward and up to release it from the clips at the bottom of the panel, and unfasten the electrical wiring connector from behind the front panel by hand.
8. Place the front panel out of the way, and unfasten the screws on the shroud cover inside the dryer cabinet with a screwdriver, removing the cover from the cabinet.
9. Locate the idler pulley and motor in the back of the dryer cabinet on the base, and loosen the dryer belt by unfastening the bolt on the idler pulley with a socket wrench until the belt is loose enough to remove by hand.
10. Take the dryer belt off the pulleys and drum, and install the new dryer belt around the drum and the idler and motor pulleys.
11. Tighten the bolt on the idler pulley with a socket wrench to secure the new dryer belt, and reattach the shroud cover with screws.
12. Slide the front panel back over the clips on the base of the dryer, and lock the panel into place by attaching the screws to the inside top of the panel.
13. Lower the dryer top back down to the top of the cabinet, and press down to lock the lid into place on the plastic clips.
14. Reattach the screws inside the lint filter slot, and slide the lint filter back into place.
15. Plug the electrical cord of the gas dryer back into the outlet, and turn on the gas valve to restore the gas supply to the
Good Luck!!
Thanks
Mar 26, 2010 | Frigidaire GLGR642A Gas Dryer
How do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
Sep 10, 2009 | Tower Aloha Breeze Fan
Need to replace flip lcd housing
its pretty simple
1. remove 4 screws in the back of phone.
2. remove back cover
3. unclip lcd connector from main board
4. remove main board
5. reassemble with new flip
Nov 22, 2008 | Motorola Mobility i560 Cellular Phone
How do you change the faceplate on the nextel i95?
BASIC disassembly of your phone(i60/i90/i95)
This ONLY covers unscrewing the housing and splitting it open? that ALL. You'll need a T-8 torx driver for this.
Step 1: Turn you phone off, turn it over, take off your battery cover, take out your battery, and take out your SIM card. Be careful with your SIM card. Unscrew your antenna, remove it, and take out the metal antenna tube.
Step 2: Get your T-8 torx. Unscrew the THREE torx screws in the battery compartment. They are located in the bottom two corners and in the top left corner of the battery compartment.
Step 3: Peel back the right hand side of your ?Nextel? sticker just above the battery compartment. Peel it back ONLY A LITLE, until you expose the fourth torx screw. Use your T-8 torx to unscrew it.
Step 4: Carefully separate the two halves of the housing. BE CAREFUL, and keep in mind that at the top of the phone (near the flip hinge) there are cables still attached (the flip ribbon cable and the headphone jack). You will not be able to separate the two halves of the phone body all the way and will want to make sure to keep the top part of the housing relatively close together. If you screw up and damage the cables up there? don't try to blame us? we warned you.
Step 5: Do whatever it is you wanted to do that required you to split apart the housing in the first place (e.g. replace a keypad, PTT buttons, etc.), put the two halves of you phones body back together (carefully aligned) and screw the torx screws back in.
Step 6: Put your antenna, SIM, and battery back in, and you're done. Enjoy!
**Now let's talk about the flip. This ONLY covers the removal of the front and inside lenses of the flip. If you want to remove your flip completely, or remove the LCD of the i90. SEARCH the forum for info on how to do that. You'll need a T-6 torx, a SMALL flat-head screw driver, a hobby knife, and a blow-dryer for this.
Step 1: _This is optional, but is ideal for those nervous people out there who don?t want to take any chances. Remove your antenna and battery but put your battery cover back on.
Step 2: FIRST, open the flip. With the phone facing you (as if looking at your screen), look into the gap between the flip hinge and the phone body in the very center of the flip's hinge. You're going to see a small slot in there. Remember that slot? it's important.
Step 3: Close the flip and turn on your blow-dryer. Keeping the dryer about 4 inches from the surface of the front lens (the blue thing on the i95 or the silver thing on the i90) heat up the lens surface. Keep your blow-dryer moving around? DON'T concentrate it in one spot, you'll end up melting something. All you want to do is soften the glue a little. You don't need to use the dryer for too long to accomplish this. A minute or LESS should be fine, use your GOOD judgment.
Step 4: Once you have heated up the front lens enough to soften the glue underneath, quickly open the flip and use your small screw driver and poke it through that slot we talked about in step 2. You are pushing on the back-side of the front lens when you do this. BE GENTLE! You should be pushing the top of the front lens away from the top of the flip. Manipulate the phone in your hands as necessary so that you can hold the top of the front lens away from the phone. Remove your screw driver and close your flip (careful not to let the part you pushed away slip from your grip.)
Step 5: GENTLY pull the front lens away from the flip a little bit and use your hobby knife to cut away at the glue. BE CAREFUL not to knick or cut ANYTHING EXCEPT for the glue when you do this. In this process you will cut a little, and pull a little further away, cut a little, and pull a little further away. Continue this until you have completely removed the front lens. Once completely separated, make sure little to no contact is made with the glue on the back of the lens or the front of the flip. The more you touch it, and/or the more **** that falls onto it (dust or dirt or whatever) the less sticky it will be.
Step 6: Use your T-6 torx driver to unscrew the four torx screws on the front of the flip. These screw hold the inside flip lens down, so once they are out, be careful when you open your flip.
Step 7: Open your flip and gently remove the inside lens. BE CAREFUL. On the i95, the LCD is NOT glued to the inside of the flip. It is held in by the inside flip lens. You'll need to GENTLY remove it from the lens. If you're not careful.. you'll damage your ribbon cable and be screwed.
Step 8: Once your done doing whatever it is you wanted to do that required you to take your lenses off in the first place, just reverse the processes in step 7 and step 6 to attach your inside flip lens again. Then simply pres your front flip lens firmly back in place. If you were careful, the glue should be undamaged and would be PLENTY strong enough to hold your lens securely in place. Presto, you're all set! Enjoy!
May 29, 2008 | Nextel Cell Phones
Cracked i880 screen
It is possible but can be difficult. there are seven T6 screws two of the are hidden under cover plugsa the bottom right and left corners of the phone on the rear. there is also one near the top left hand corner near the antenna.Once open you will see that the phone has a ribbbon cable that connects the flip to the main board. Carefuly remove the cable and replace the flip..then make sure to seat the new flip correctly and replace the backhousing and screws..good luck
Jan 01, 2008 | Motorola Mobility i880 Cellular Phone
Kenmore canister model 116
Yes. Remove the top plate on the power head. Remove the two screws. Flip the power head over. Insert a flat head screw driver into each of the marked slots and separate the two pieces. It takes about 2 minutes.
Dec 20, 2007 | Kenmore 22812 Bagged Canister Vacuum
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Oct 27, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
