Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
TV clicks but does not switch on
I have a widescreen CRT Sony TV, it started to click only but would not turn on, almost like powering up then stopping. Is this the PCB?
  • 666 Answers
Yes mostly have problem with ckt board, and you need to trace first in power supply ckt area. monitor if b+ voltage give normal going to horizontal transistor.
Posted on Apr 03, 2010
Click tv on but nothing happens stand by light blinking
Check to see if there is an alternate power switch, my TV has (2) power switches, one turns the power on but not the TV and the other turns the TV on as long as the power switch is on.
Apr 22, 2010 | Sony FD Trinitron WEGA KV-27FS210 27" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY KV34HS510 always worked perfectly but today it wouldn't turn on by remote or button on TV. It makes the same "click" sound which it always did before coming on but it just immediately clicks again to...
You need to bring it to a TV technician. There is a relay inside the TV which can be blocked by any few errors that may occur in your TV, for protection. Only a tech may discover the problem.
May 25, 2009 | Televison & Video
Sony tv will not turn on
the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
powersupply rectifier diodes, power trasistor lekage,
diodes, zener diodes,
if a 90-110 volts to the line trasistor,
a line transistor be checked.
the tv simple problem
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
The TV will not come on
The power supply on the tv may have gone bad.
Dec 07, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Jul 31, 2008 | Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony Trinitron TV takes multiple manual clicks to turn on.
If you mean the actual mains switch needs multiple cycles, it could be faulty.. does anything, say a power indicator, come on when the TV doesn't?
If the actual switch is OK, then you probably have a fault in the power supply section... often faulty electrolytic capacitors. U need service.
Mar 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV Problem model # KV-27V42
your tv has a  short  circuit, the power supply see that and put away the polarizatio n , you have to check  if transistor of power on flyback transformer is  good
or bad - delfo
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
