Question about Garden
After I start my lawnmower, the rpm?s oscillates up and down for aprox 15 to 40 sec and then stabilizes.
  • Samuel Charles Spriggs May 11, 2010
    It sounds like the governor needs adjusting. But if it stabilizes at the correct RPM, I'm not sure I would worry about it -- does it stabilize at the correct RPM?
  • Spike Nov 23, 2012
    John Bridgers answer is spot on. If I add one suggestion, if it is a diaphram type carby (eg: Sprint) replacing the diaphram when disassembled is recommended. have fun.
  • 246 Answers
Hello:
>>The Cause of this is a Slightly Restricted Passage or Jet in the Carburetor and it Takes a Few Seconds for the Governor the Engine at a Slightly Higher RPM to Compensate for the Restriction.
>>The Restriction is Usually Varnish that Builds up Over Time and Usually Requires Soaking the Carburetor Overnight in Cleaner to Correct this Problem.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Hope this Helps. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on Apr 22, 2009
Why does 1991 montero Engine rpm oscillates?
POSSIBLY AN INTAKE MANIFOLD LEAK CAUSES PULSING DUE TO MIXTURE VARIATION
Jan 02, 2018 | Mitsubishi Sigma Cars & Trucks
21" Troy Built Self Propelled lawnmower engine won't start.
Remove spark plug, clean or replace. Remove air cleaner, clean or replace. Ensure oil is full. 30w. Drain old gas out of tank. Fill with fresh gas with Stabile added. Remove bowl from bottom of carb. clean. Observe bowl screw, see if hole goes thru screw. Clean out. Bread wrapper works nice. Observe float. Float down gas flow, float up no gas flow. Re-assemble, prime 3 times, pull rope 10 times to start. No start replace carb.
Jul 30, 2013 | Garden
Lawnmower starting problems
Clean or replace air filter. Fill oil, 30w. Clean & gap plug or replace.
Remove carb bowl from bottom of carb & clean. If gas is 30 days or more old, use fresh gas with Stabile.
Jun 19, 2013 | Garden
I have a Toro 16.5 riding lawnmower it stop and wouldn,t start back what could be my problem?
Battery charged? Bad fuel? Low on oil? 30w oil required. Clean carb. Check for improper ground on starting circuit. Ignition switch providing power to starter when key turned? Always use Stabile in gas. Remove bowl from carb ensure float is working properly. Float up no fuel flow, float down fuel flow. Ensure oil is full, low oil shutoff will not allow starting.
May 30, 2013 | Toro Lawnmower Lawn Mower SP Drive Belt...
On the EP-4PCIA, when pressing the on/off button the pc does not start. What is wrong?
are you holding down the on/off button? momentarily press one time and release. if nothing unplug the pc from the wall and verify everything is plugged in securely and then plug everything back in and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jun 11, 2012 | Computers & Internet
RPM is @1500 say 60 Km an hr, when I lift off throttle rpm jumps up aprox 300 rpm. And why does it take so long for rpm to come down?when it does it drops to 1000,i touch accelerator very light-ly it...
Disconnect the battery for 10 minutes reconnect the battery then start the car and put it into the D postion with your for on the brake for 30 seconds then while still holding the brake put the car the N postion for 30 seconds still holding the brake now put the car back into the D postion for 30 seconds then put the car into the PARK postion and shut it off. Wait 10 second then start it and take it for for a test drive. Make sure the a/c is off and the radio,wipers are off while doing this procedure. This is called an adaptive relearn.
Apr 28, 2011 | 2003 Chevrolet Impala
"Stability Control Fail" light on.
first job is to check the part load and main beather hoses are ok the stability system light may be a false indicator if the engine has stalled best is to get fault codes out of the ecm with a code reader to help but air leaks on the engine inlet side can cause strange/seeming unrelated symptoms
Aug 22, 2017 | 1997 Jaguar XK8
1993 chevy pickup hard starting and tach oscilates 200 rpm up and down
sounds more likley you have an air leak this will cause bad starting as it is sucking air in instead of fuel when its cold and wnen it warms up idling will be eratic and misfire check all hoses gaskets relating to the inlet manifold or if its done that kind of mileage crankcase pressure could be the problem but i suspect an air leak yates210456
Aug 22, 2008 | 1991 Chevrolet K1500
Rough idle
I took mine in to change the plugs and they said there are four O2 sensors in the fuel mixture system and two were bad. I didn't replace them since they were a little pricey ($500 to replace both) and I have 103,000 on the car. Has very similar roughness and occasional oscillations, but no stalling. Hope this helps.
Jul 21, 2008 | 2004 Mitsubishi Endeavor
Shut down after 30seconds
There has been a similar question, which was answered by kimi here: http://www.fixya.com/ThreadView.aspx?thid=101354&prdid=231850 Hope this helps.
Jan 26, 2006 | Panasonic PT-56TW53 56" Rear Projection...
Garden Logo
913 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
