Question about Bissell 9200 Upright Vacuum
Bissell 9200 will not spray
Bissell Model 9200 will spray for a moment then start blowing air through the lines. After a quick tear down found out all the lines were not kinked or clogged. Could not find the heater element in the handle, must be in the base. I think something is clogged or the pump might have air in it. would like a second opinion.
  • Chad Apr 22, 2009
    tore apart unit and cleaned hoses. no debris in the hoses. assembled unit and turned on. switched cleaning selector between water rinse and heavy traffic a few times with the hand tool in spray. found out whenever the soap is applied the stream would stop. i believe it is the soap pump. any thoughts?
  • lacnmac Apr 27, 2009
    the rollers turn but the water and solution does not come out
  • 29 Answers
SOURCE: Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
  • 29 Answers
SOURCE: Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
SOURCE: I have a Bissell pro heat water will not disperse from
Absolutely the right answer for me. Couldn't get it to work no matter what troubleshooting Bissell suggested. Took apart the sprayers as above suggested and it works as good as it did the day I bought it. Thanks.
Posted on Jun 12, 2009
  • 33 Answers
SOURCE: Bissell 9200 upright carpet cleaner does not spray
It could be the pump. You can open it up and see if the pump is working by taking the pump input tube and inserting it into a bowl of water. Pull the trigger and see if water is leaving at the pump output.
However, ensure you have the simpler things covered first:
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Posted on Jan 24, 2010
  • 17 Answers
SOURCE: My Bissell Proheat Turbo 2X does not spray water and solution
Here is what to do
Posted on Feb 08, 2010
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
Jan 15, 2013 | Vacuums
Bissel9200 wont spray water and solution
Here's a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
If you continue to experience difficulty, here's a link to locating one of our Authorized Service Centers.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 23, 2012 | Bissell 9200 Upright Vacuum
Have a model 9200 that is not dispensing fluid,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell - ProHeat Mod. # 9200 05240C - No
heatman101
hjghkl
Jun 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 8920 wont spray any water/ solution except when in water
It sounds like you have a clogged line, if your mechanically inclined you can fix this yourself by tearing the unit apart. If you open the unit up, disconnect the lines on your pump and blow an air compressor through them. certain lines require you to press the switch at the same time as blowing the air through them. If you have the receipt contact bissell and they will refer you to the local warranty center
Aug 29, 2009 | Bissell 8910 ProHeat Clear View Upright...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 9200 Upright Vacuum Logo
251 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
