Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
FE Light Our PAC L90, Delonghi Pinguino is flashing a FE light on the front. It won't turn on and I have pressed the reset button.
You need drain the water and then function normally.
Posted on Oct 02, 2007
DeLonghi PAC L90
I would venture that your unit requires cleaning of the filters or at worst it may be a fan motor. Initially, try removing the front panel holding the filters and clean it as instructed in the user's manual. Should this not be corrective, i would suggest to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | DeLonghi PAC C100 Air Conditioner
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
How to conect my air condittinion pinguino pca L90
This really Expensive AC quite on me. The fan works great, I hear the Compressor turn on and it still doesnt blow cold air. Should I flip out?
May 14, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pinguino PAC L90 is flashing Lt on the display.
It is in Frost Prevention mode - the appliance will start up again automatically once finished.
Nov 18, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
1,253 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
