SOURCE: I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
SOURCE: Yard Machines 22" push mower
Hello, W/D here.
2 suggestions: 1. Check the fuel cap for pluggage, paying particular attention to the pinhole vent in the cap, and 2. Clean the air filter. A plugged (or nearly plugged) filter can also cause these symptoms.
Best regards, --W/D--
is the spark plug wire still off from shipping?
SOURCE: surging problem on 10 HP Briggs & Stratton rear mounted engine on @86 Snapper mower
Dirty fuel in the tank, breather in the filler cap blocked, or partly blocked main jet in the carb, if there is a fuel solinoid on the base of the carb check its function by removing, when the ignition is turned on the plunger should retract into its housing,
