Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it. Any advice of the problem is appreciated.
  • 502 Answers
The zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Posted on Apr 24, 2009
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune 30GB won't charge in car.
Some auto usb cables aren't compatable with Zune device.
Mar 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune screen is black and won't charge
you could have a bad charging cord and also you can try to turn the hold button on and off that sometimes works
Nov 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
30GB Zune turns off
i had the same problem
try this it worked for me conet you zune to a charger externaly ie not on the computer
through the mains plug adapter it works fine but when i unplug it go back to flashing on and of
let me know how you get on
Oct 22, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune Auto Reboot
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
30gb zune install
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Apr 21, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Charging
same as it does on the usb... the Zune can only handle the 5.5V(I think that's the voltage on usb ports...) so the wall chargers have to have that voltage rating...
Mar 04, 2008 | Microsoft Zune JS8-00001 Digital Media...
First time chargin Zune 30GB Brown
I had the same problem (frozen after first time trying to charge.) I found the solution on another site. I just unplugged the device and let the battery drain completely, then plugged it back in (rear usb port) and voila, it works, that simple.
Nov 30, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
166 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
