Question about Directed OHD900 Car DVD Player
Screen shuts off if lowered too far
The DVD works fine and the lights, etc. The screen shuts off if it is pulled down all the way. It works if it is pulled down part way. Do I just need a new ribbon cable?
Yes I have had this problem , and have traced it to both pc leads between main unit and screen with some tracks of the leads open circut due to kinking
Posted on Jul 19, 2008
SOURCE:
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Why cant i reboot my laptop i press enter and it doesnt work
Enter will not reboot your laptop unless you have the menu pulled up to do a restart. Use your mouse pad and go to the lower left hand corner of your screen you should see a microsoft logo on the very bottom of your screen far left hand side the first button on the bottom lower left hand side. Click on that button and a menu will pop up depending on the version of windows you are using you may see a window with writing in it it may say shut down or sleep but to the right of the window you will see a small triange. Click on that triangle and a drop down will appear select restart and your computer will reboot for you.
I hope this helps you out.
Apr 01, 2011 | Computers & Internet
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
Will not go on or print
Hi there, I was able to solve the problem by taking all the cables, connections etc.all out and started over and it works fine. ( well so far anyway.)Actually I need to confess , my husband did it. ( I know next to nothing about it.)
Thanks for the speedy reply.
Jan 06, 2009 | HP Office Equipment & Supplies
Sampo DVE-611 apparently powers up from front panel switch (w/red light) LCD display, etc. No other buttons work, incl. eject. Remote completely unresponsive. Unit shuts down about 10 sec. later. Anyone...
After several power ups, the front panel buttons eventually "woke up". Replaced remote, and everything's working fine. Not sure why the front panel was temporarily unresponsive.
Jul 16, 2008 | Sampo Televison & Video
Toshiba Satellite A60 powers up then off after 2 seconds
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
Jan 06, 2008 | Toshiba Satellite A65-S126 Notebook
Directed OHD900 Car DVD Player Logo
114 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ric Weide
Ric Weide
Level 1 Expert
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
