Question about Tomtom Go Plus GPS Receiver
Tom tom 500
How do i change the battery myself
    Problem Solver:
  • 5 Answers
The thin metal surround can be removed after cutting sticky foil.
There are 2 screws holding the battery in place.Be carful removing metal surround,there will be wire through in slot.
Disconect battery lead from board,the battery can then be prised out,its pushed into a frame clamp.
Posted on Oct 16, 2008
Well I got to the battery, but still haven't figured out how to get it out. To get to where I got to first pop the front silver suround off then remove the 4 retaining screws and the body will come off, next cut the foil around the speaker and take out the 2 screws, you can then see the battery. Where to from here? please!!
Posted on May 05, 2008
SOURCE:
How to replace battery in tom tom 500
You'll need a special 'torx' screwdriver to remove the screws to replace the battery. The battery and the torx screwdriver can be purchased together on eBay for less than $20.
Click here: http://bit.ly/c6sbyk
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 07, 2010 | GPS
Tom tom 125.se will not recharge battery threw my lighter type power supply. i put this lighter power supply in myself it runs other thing just fine . it just won,t recharge the tom tom battery.
You have another option. Connect the GPS unit to a USB port on a computer. And please use the USB cable supplied with your unit.
Dec 30, 2009 | Tomtom GPS
Tom tom one not turning on used 3 months
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Regards and I hope this helped.
James
Sketchlab.com
May 28, 2009 | Tomtom ONE GPS Receiver
Tom tom one battery change
I too dropped my tom tom go 300. It appears the battery was disloged as it will only work if attached to another power source; AC Adapter or cigarette plug. Does anyone know how to open the case to check on the battery?
Feb 28, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 300
you have te release the front cover. Then you see a couple of torx screws. Release them and the tomtom is open. You can change the battery
Jan 04, 2008 | Tomtom GO 300 GPS Receiver
Activation code missing from secondhand tomtom, think its a 500 go
I have managed to load a downloaded map onto two separate Tomtom one XL devices. I did it through tom tom home. I purchased , downloaded and installed the map on my first device. Then connected my second device to my computer. In TOM TOM Home I then changed my device using the Device menu / Change device. it then allowed me to load the map onto a second TOM TOM device.
Nov 29, 2007 | Tomtom Go Plus GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
Tomtom Go Plus GPS Receiver Logo
226 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
