Question about Acer Aspire 3680 Laptop
My needle in the chager jack is very loose and wont charge.
My needle in my charger is very loose and wont take a charge can you please help me computer expert.
  • darksoul678 Apr 22, 2009
    HOW DO I FIX MY POWER TIP!
  • 230 Answers
You can buy them in most electronic stores just take the old one in with you. If you ask nicely they may even solder it on for you. (especially if your female and hot LOL)
Hope this helps
Posted on May 06, 2009
Why wont my black ops tango headset charge? Also the charging light is pulsating?
Look if you have a problem with the battery or the charger. You can verify with electronic tester the output of the chager.
I don't know if you can replace battery.
Aug 28, 2015 | Radio Communications
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Msi laptop not charging/no power to good new charger
The DC jack in the laptop is a common source of trouble, from no power to intermittent operation. The computer will need to be dismantled down to the motherboard level to access the part.
May 22, 2012 | MSI Wind U100-280US Netbook
Spice m-4580 invalid charger problem.
SIR. 4580 MOBIL ME CHARGING INVELID LIKHA AA RAHA HAIN
Sep 05, 2011 | Health & Beauty
My toshiba satellite l300 suddenly not charging. might be the loose power jack, battery or the charger... how can i check which of these is the root cause?
Does the laptop work on the ac adabpter? If it does, you probably require a new battery. Ebay will be the cheapest source of original and copy batteries.
If it doesn't, you probably require a replacement ac adapter, Ebay again.
Hope that helps.
Jan 20, 2011 | Toshiba Satellite Pro L300 Notebook
Hp pavilion entertainment pc wont charge or turn on
Check the charger is throwing out the correct voltage at the DC jack
Do you get any lights flashing at the charger? If you do it indicates that power is not completing the circuit and is being "spat back". This would indicate a damaged charging circuit or possibly a loose power jack socket, if it feels loose as you plug it in, you may need to change the DC socket
Jan 03, 2011 | HP Computers & Internet
It will not turnm with out the chager and it is chager all the way
Dear, you must change your battery, i mean get a new battery and then charge it. So after it charge unplug charger and turn on the phone.
Thank you
May 16, 2010 | Samsung FOR SAMSUNG INSTINCT S30 M810...
The car charger on my nuvi 255wt garmin has stopped charging the unit. Not sure what to do.
just at the end of the chager (the sig plug end) the end winds off like a bolt behind it ( dont loose the spring) is a fuse if its blown reolace it if not replace the whole charger
good luck
May 13, 2010 | Garmin 255WT GPS Receiver
Garmin charger problems
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin nuvi 200W GPS Receiver
Toshiba Gigabeat wont charge or turn on
There is a smill switch on bottom, you need a paper clip switch it off and on a few times.
A FULL CHAGER FOR ME LAST ABOUT 2 HOURS
Sep 04, 2007 | Toshiba Gigabeat MEG-F10K MP3 Player
Acer Aspire 3680 Laptop Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
