Question about kawasaki Full Suspension Mountain Bike Men
Scag SMT61A Mower with Kawasaki 27KA engine. 200
Scag SMT61A Mower with Kawasaki 27KA engine. 200 hours. Was running fine, then just died. Cranks fine. Gas flow to carburetor fine. Remove breather put gasoline directly down throat of carb, runs until gas is used up. Problem seems to be carb. Suggestions?
  • richard_jone Apr 24, 2009
    The bowl of the carburetor has a fuel sending solenoid on the front with a wire coming off of it. If this is bad, no gas will get past the carb. Solenoid plunger might be stuck, tap on body of solenoid and try to start it again. If this doesn't work, it probably needs replaced. Part costs any where from $125-$165.
Look on the bottom of the fuel bowl. See if it has an electric fuel shut off solenoid. If it does unscrew the solenoid clean with Carburator cleaner and work the needle up and down until free. When you have it off of the carb plug it back in ground it to a metal surface and turn the key on and off. Watch the needle move up and down. Install back on Carburator bowl and start it up.
Posted on Apr 15, 2012
    Champion:
  • 225 Answers
Try taking stater fluid to carb and try keeping it running,needle seat might have some dirt in it or the carb itself needs to be cleaned.
Posted on Jun 07, 2009
I have a scag turf tiger and when I place the mower under load to cut grass it dies on me
Check the air and fuel filters? They could be clogged, especially if it's running rough
May 10, 2016 | Scag STT61V-791DFI-SS Gas Turf Tiger...
Scag tiger cat wont start
I would put new plugs in change the oil put a new in line gas filter in. After this tune-up check for spark by leaving the plug out on the moter body crank it over if the spark is hot you know its a gas problem also check for any grounding by starting it at night then looking around to the engine to see if its grounding out. Try these simple things. Do not change anything on the moter without doing these things first. Good luck
Apr 11, 2014 | Scag Tiger Cat 52 Zero Turn Mower...
Scag mower
If equipt, check the low oil switch circuit. Might be a failing switch.
Sep 24, 2013 | Scag STT61V-791DFI-SS Gas Turf Tiger...
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
kawasaki Full Suspension Mountain Bike Men Logo
1,147 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
