Question about Frigidaire Affinity ATF7000E Front Load Washer
Pau err Frigidaire affinity frontload washer stuck on normal cycle flashes pau. when u press any button or turn knob it flashes err. only have start/pause button and cancel button no stop button. tried to hold them together for a while same result. also tried to let it unplugged for some time. no help.
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
  • 1 more comment
  • moofuss May 16, 2011
    Mine did same thing and everything I read pointed to contol board. I removed control board and with power on I started unplugging every plug on back until I heard a click, then I tried cancelling it and it did. Apparently one of the plugs I unplugged trigered something and it works fine now. I did this after trying unplugging it from wall and everything else I could think of before I did this.
  • Gordy Iverson Jun 05, 2011
    Right on, we were headed out tomorrow to get a new washer. Did what you said starting at the right side of the control board, i believe the 3rd plugin and out and wha la!!!!!!!!! Working just great right now! thanks very much for the info.
  • sema6144 Sep 06, 2011
    I tried this method and it didn't work, I still have Pau error code any one have any ideas?
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Dec 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
New frigidaire washer (affinity)
Kimberely, The err 47 means that the control board is not sensing the door lock. First try unplugging the machine for 1 minute and see if it comes back to normal. If it doesn't put it into the door lock test, with the door closed, by doing the following: Turn the program knob to drain spin. Press pause cancel to turn off the LEDs. Within 5 seconds, press and hold the option and pause cancel buttons until the LEDs start sequentially chasing, then release the buttons. All the LEDs will sequentially light. Turn the program knob 4 clicks from the start position clockwise, the door lock solenoid will activate. The door should be locked. Turn the knob one more click clockwise and it should unlock. You can toggle back and forth to test it. If the door lock is working and you are still getting this code, then its a control board problem. You should call for factory service. If you have any more questions, you can email me at catriver1@gmail.com Catriver...post back.
Jan 20, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity ATF7000E Front Load Washer Logo
1,254 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
