Question about Garmin nuvi 350 GPS Receiver
Gqrmin 350 GPS Receiver wont turn on
I have a garmin gps 350 receiver which wont turn on. Is there any way to solve this or any repair outlet I can send it for repair. BTW the gps is out of warranty
  • 6 more comments
  • Anonymous Nov 26, 2007
    I have the same problem, My Power button does not work. I was able to plug it in to a computer and unplug and was able to use it on the battery. Once I unplug and use it on battery, the only way I can power it off is by pressing the Reset button on the back.
    Can any one help me determine what would be the problem?
  • bowwows Feb 08, 2008
    the screen is blank. it wont turn on. I tried both battery charge and wall plug.     it is app. 1 year old. is it common to last only one year.
  • Anonymous Apr 12, 2008
    Garmin NUVI 350 will not turn on
  • niinjakelli Jun 14, 2008
    I have a Garmin 350 GPS, and the screen stays black when I turn it on. I cal touch the screen and it makes the noise of me pushing buttons, but it is only black.. what do I do???
  • Anonymous Jun 18, 2008
    While turning off the power button, it made a strange noise. When, I tried to turn it back on, the screen remaines blank. It does not go on when plugged into the car charger or the wall outlet charger.
  • tgg901 Sep 05, 2008
    My Garmin was working and it wasn't being used for several months and when I needed it the unit would not turn on. I put it on the charger over night and it still does not turn on. I saw a post to check with meter but what contacts are you talking about? I know 0 about electronics. I need detailed information.
  • rams_jaguar Feb 09, 2009
    I have a Garmin Street Pilot C580 GPS. It won't turn on. I have tried charging it through car charger, computer, wall outlet charger . None of these seems to be working.
  • Anonymous Mar 29, 2014
    reset
I have a 350 garmin and it when i put in a name of a place it says no matches found??? how can i fix that???/
Posted on Sep 10, 2008
  • Garmin Master
  • 2,130 Answers
Dead Battery? That makes no sense at all. He mentioned he was running it off the battery - " I was able to plug it in to a computerGqrmin 350 GPS Receiver wont turn on - 1.gif and unplug and was able to use it on the battery. Once I unplug and use it on battery, the only way I can power it off is by pressing the Reset button on the back."
The fact of the matter is that there is a well known issue with Nuvi 350 Power switch. I haven't taken mine apart yet (also bad power switch), but most likely the switch is defective or the solder joints are broken.
Posted on Jan 14, 2008
    Novelist:
  • 113 Answers
Sounds like a dead battery.  Put a voltage tester on the contacts to see if there is any juice.  If the battery is bad it may appear to be charging but not accept the charge, this may also inerfere with the external power. Also check the fuse in the tip of the cigarette adapter plug.  Have you tried powering up when the USB is plugged into your computer?
Posted on Oct 26, 2007
SOURCE:
My gps only show garmin on screen wont turn on
This GPS will need to go back to Garmin for repair, they really don't repair them but give you an exchange unit, so with prices low just replace it.
Oct 19, 2014 | Garmin nuvi 255W GPS Receiver
My garmin 350 gps reads "gps is off" and doesnt work. it also always has the wrong location. how do i turn the gps on?
the gps is turned on by raising the piece in the back that is actualy the antenna....if you havent done this thats the problem.if you have then someting is not reciaving a signal and would have to be repaired...btw the piece is sometimes mistaken as a prop like on the back of a picture.....hope this helps
Aug 18, 2010 | Garmin nuvi 350 GPS Receiver
Stuck on loading maps
Egypt Maps for all Garmin GPS
www.a100100.com
waleed hagag
+2 010 0002506
Jan 12, 2010 | Garmin nuvi 350 GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
My Garmin nuvi 350, North America, will not show picture.
Has your problem been solved? If you need more information, I will be happy to try to assist you.
Jan 10, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
540 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
