Question about Palm Tungsten E2 Handheld
Power button will not turn pda on or off
Unable to turn Tungsten E2 on or off with power button
    Guru:
  • 832 Answers
Hi thanks for using fixya!
Try to remove and install back again the battery. Then try to turn the power on again.
If you need further assistance, let me know.
Posted on Apr 22, 2009
How to change from com 1
Palm (PDA) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Palm_(PDA)
WikipediaThe Palm Treo 700p is one of many smartphones produced that combines Palm ... Although HP kept the Palm brand initially, all new PDA devices announced at press ....In order to try to change this trend Palm had been working on a new ...
How to Replace the Battery in Your Palm Tungsten E2 PDA ...
? 4:34
https://www.youtube.com/watch?v=caJVwecskho
Sep 2, 2007 - Uploaded by Aaron Kelly
How to Replace the Battery in Your Palm Tungsten E2 PDA. Aaron Kelly ... for battery replacement. Includes one year money back guarantee!
[PDF]Handbook for the Palm Tungsten E Handheld - Textfiles.com
pdf.textfiles.com/.../PDA/PalmOne%20Tungsten%20E%20Handheld.pdf
Chapter 1: Setting Up Your Palm™ Tungsten™ E Handheld . . . . . . . . . . . . 1. System requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Jan 03, 2016 | Palm Computers & Internet
Hello, it seems my palm Tungsten E2 is not compatible with Windows 7 (hotsync). Anything I can do or is there another PDA that will work? Thanks, I do need the PDA.
you need to uninstall the version of palm desktop that you alredy have and install the 4.14 palm desktop, with the hotsync manager that 4.14 includes you should have no more problems
Feb 01, 2010 | Palm Tungsten E2 Handheld
HotSync problem:connection could not be
After you change the battery you need to do a hard reset. This will erase all the info in your pda so you want to make sure you have it all backed up on the palm desktop To do a hard reset follow these steps:
1. Hold down the power button.
2 While holding down the power button, use the tip of the stylus and inset it into the hole in the back of your pda and gently press and release the reset button in the back of your pda.
3. When you see the message that warns you about erasing all of the info on your hand held select continue.
4. When prompted follow the online directions to align the screen. After that you will want to do another hot sync. Best wishes.
Aug 10, 2009 | Palm Tungsten E2 Handheld
Tungsten E: difficulty starting and turning off
PalmOne had a manufacturing issue in the Tungsten E and E2 PDA versions.
Bottom line is the On/Off switch is not properly soldered (enough soldering amount) so is easy that breaks the soldering joint of the switch to the main board.
The repair requires to open the PDA, remove very carefully the mainboard, and put straight (vertical) and re-solder the switch again.
It is needed a minimum of tools for it (soldering iron, torx screwdriver, wire soldering, plastic pry tool), and some skills and experience in fixing electronics.
Also, you can get with a radio or TV repair techniocian, and ask specifically to resolder such On/Off switch.
Best regards,
Jun 08, 2009 | Palm Tungsten E2 Handheld
The ''power'' start button does not work
i have a dell 50 axim , the start button will not start the pda ...do you have a solution.
Apr 09, 2009 | Palm Tungsten E2 Handheld
Powers up w/o pressing the power button
Press soft reset on back while turning ir on.
Jan 03, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 will not power on
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on PDAsmart.com that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Jun 06, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 PDA battery
E2 has a great battery might not be it. Its not easyly replaceable like in some other models.
the battery can be replaced by a professional or by yourself.
The pda should work on charger? does it work while pluged in?
If it doesnt work while its pluged in theres something more seriour wrong with it.
You can try soft and hard reseting.
Instructions can be found in this pdf file http://www.palm.com/us/support/handbooks/tungstene2/en/maintain.pdf
If you cant open pdf files you need to find yourself pdf reader, google pdf reader and get one.
If soft or hardreset have any effect and the device still doesnt work even on charger then it has a hardware issue and I recommend contacting palm or the place where you bought the pda and findout about repairs and possible price, may be high.
good luck and if theres anything else let me know.
Feb 19, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
