Question about LG LDF6920 24 in. Built-in Dishwasher
Not really a problem, Ijust want to know how long a normal cycle should last.
    Genius:
  • 1,605 Answers
Wash cycle is between 10-14 munites. rinse cycle is about 10 munites. pluse time to fill and discharge water from the tub. total time should be about 40-45 munites
Posted on Apr 22, 2009
Hi how to convert to kilowatt hour using this meter? Do we really need to multiply by 20
Yes, you do have do multiply, but not the number on the dial itself. This is a commercial or heavy residential use meter. They are geared so that each kilowatt hour measured by the dial is actually 20 kilowatt hours. This is done since some users use so much power that the meter could actually roll over during a normal billing cycle using a regular meter. So, if you are reading this meter to determine how many kilowatt hours you have used since the last reading, you simply read the meter as you would any normal meter to get the number displayed. Your photo reads 13525. That is your current meter value. If you last bill stated the meter value was 13501, that would indicate that you used 24 (13525-13501) times 20 or 480 kilowatt hours since the last bill.
Hope this helps!
Aug 15, 2016 | Office Equipment & Supplies
Power Cycles
Most likely A power supply problem, you can try unplugging the cord waiting 3 minutes and retrying, to see, if not the open the back and see if the caps are in good condition, even though it did this last year, could be more a problem now since last 1.5 years ago its was something else. If you don't know how to solder then time to call a repairman.
May 11, 2014 | Philips 47PFL7432D/37 TV
How to reset the drive cycle on a 2001 lincoln towncar
Shouldn't have any issues just changing a battery on a lincoln
No drive cycle requires much in the way of any miles
Usually two runs to 60 & back to 35 without touching the brake
Something like that.
Normal driving you shouldn't even have to know anything about
drive cycles
When your not accepted at inspection you got other issues
The Evap System is the last to run on my lincoln & may only
do so every few days
Really need to look at professional scan tool data before
you go the inspection, to see that all monitors are clear or have run
Jan 28, 2013 | Lincoln Town Car Cars & Trucks
+5 volt mosfet 40t30h is blown out and near by mosfet p3055ld is also shorted ijust replace both with 55n06 is it working?
Try for your self to know that it is really working. Take the risk. But if you know that it is the right thing you replace then it will work.
Oct 29, 2009 | Gigabyte GA-8S661FXM-775 (4719331838096)...
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Jenn-air model#jcd2389gew how do you get water filter light to turn off. ijust changed the filter and the light came on after 1 week
push the light and lock button simultaneously for about 5-8 seconds, that should revert it back to normal status.
Jun 13, 2009 | Maytag MSD2454G Side by Side Refrigerator
Kenmore 90 series
The tub sometimes gets moved to one side. Open lid and center the tub before you test run try that first.
Jan 16, 2009 | Kenmore 23822 Top Load Washer
LG LDF6920 24 in. Built-in Dishwasher Logo
152 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
