Question about HP (D7580-60003) Motherboard
Electronic engineer YANG AN YA-1 E114139 94V-0 made in taiwan p/n 580-g2a. pls sended all circuit detail me if you are provide . thanks kstarmalik@yahoo.co.in sanjay malik in india
  • Anonymous Jan 22, 2009
    necesito un manual de esa placa
  • Anonymous Mar 25, 2014
    pdf
How to disable onboard vga?
Posted on Oct 16, 2007
How do you replace the ignition switch on a 2002 buick century?
What do you mean no sound when turning key ? Does the car start an run ? Or the car doesn't crank ? Ignition switch's do not work the same way they did in the old days , especially on GM vehicles . The ignition switch is an input to the BCM - body control module , the BCM processes these inputs an then energizes relays to turn things on . Also sends messages to other modules for them to turn on or energize relays .
The power mode signal may be as simple as a B+ input wired to a particular ignition switch contact. If this is also the B+ supply to the module/device, the module/device will only operate with the ignition contact closed to B+. An example of this is the starter relay when it is wired directly to the CRANK/START contact of the ignition switch. When the CRANK/START contacts are closed, the starter relay is energized and provides a current source to the starter and starter solenoid. When the ignition switch leaves the CRANK/START position, the switch contacts open and the starter relay is de-energized. This removes the current source from the starter and solenoid and the starter operation stops.
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 4 signals/circuits from the ignition switch. These are the Ignition 0, Ignition 1, Crank and Accessory 1 ignition switch signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The sequence of switch closures received by the BCM
The status of the engine run flag.
Important: Any ignition switch states not covered in this table indicates a DTC setting situation.
The chart indicates the modes detected and transmitted by the BCM:
Power Mode Selected/Expected
Engine Run Flag Serial Data
Sampled Ignition Signal State
Power Mode State
Accessory
Ignition 0
Ignition 1
Crank
OFF-LOCK
0
0
0
0
0
OFF
Accessory
0
0
0
ACCESSORY
RAP
0
1 to 0
0
0
0
RAP
OFF-UNLOCK
0
0
0
UNLOCK
RAP
0
1 to 0
0
RAP-UNLOCK
Run
0
RUN
Crank
0
0
CRANK
Crank
CRANK
Run
RUN
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the BCM fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they can check for the engine run flag status on the serial data circuits. If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to "RUN". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You probably won't understand any of this info. your best but would be to take it to a qualified repair shop that has proper diagnostic test equipment !
Sep 29, 2016 | Buick Cars & Trucks
Pasword bola88 saya ada yang merubah.bagaimana caranya menemukannya ya...tlg dong...
paspowrd dan nama bola 88 saya ada yang rubah ...
gmn boss buat log inn lagi dan bermain disitus ini...
Nov 28, 2013 | google.com
Pls can i get circuit diagram and description about Mifi...?
Electronics engineer student that can't spell Engineer??? I feel sorry for you man! Also, you wrote "Pls" for Please .....are you a lazy student?
Stop using shortcuts if you intend to be an engineer, and be methodical with your writing as well as your work.
Jul 12, 2012 | Novatel MiFi 2200 Mobile WiFi Hotspot...
SAYA PUNYA MASALAH DENGAN MOTHERBOARD ASUS P45533-MX SY,DI TEKAN TOMBOL POWER KIPAS PROSESOR TIDAK NYALA TAPI LAMPU LED CONROL DEKAT SLOT PCI NYALA.TRIMAKASIH MOHON BANTUANNYA
hallo sujanajohan, coba cek kabel kipas processor apakah sudah tersambung ke motherboard atau belum? jika sudah berarti ada dua kemungkinan: 1. power supply yang anda gunakan kekurangan daya (Watt) 2. kipas processor anda sudah rusak.
jika kipas procesor anda terbilang masih baru maka kemungkinan besar power supply anda yang bermasalah. karena lampu LED motherboard hidup berarti power supply anda tidak rusak, maka kemungkinan terbesar dari masalah anda adalah daya power supply anda kurang besar
NB: jika anda membeli power supply yang harganya hanya sekitar 100ribuan walaupun Watt-nya besar seperti 450W, tetapi sebenarnya itu bukan 'truepower' sehingga daya yang dihasilkan tidak sebesar yang tertera di kardus, belilah power supply yang memiliki true power, harganya memang mahal, tetapi sebuah power supply yang memiliki true power berdaya 380W lebih baik daripada power supply 450W yang tidak memiliki true power, dan tegangannya stabil tidak merusak komponen komputer yang lain
semoga ini membantu.
Aug 23, 2011 | ASUS P4S533-MX Motherboard
I have a motherboard from a Vicon Kollector CCTV DVR that has failed. The only markings I see on the m/b are yang an ya-3a e114139 94v-0. I am trying to find a replacement since the board is obsolete...
The only motherboard I find with those ID numbers is this puppy,
http://cgi.ebay.com/HP-MOTHERBOARD-YANG-YA-3-94V-0-E114139-W-DUAL-CPU-/300439081565?pt=LH_DefaultDomain_0&hash=item45f390925d
Or this one,
http://cgi.ebay.com/YANG-YA-3-94V-0-E114139-DUAL-SOCKET-370-MOTHERBOARD-/310198934835?pt=Motherboards&hash=item48394c1d33
If this is the mobo in question it's probably one, or more of the Voltage Regulator Modules has gone bad.
(Voltage Regulator for the Processor. Two Processors, two Voltage Regulators)
Or perhaps one, or more of the Electrolytic Capacitors have gone bad.
http://www.capacitorlab.com/visible-failures/
A competent computer repair shop could replace them.
(We are getting less, and less)
Oct 20, 2010 | HP (D7580-60003) Motherboard
I need a manuel to show me how to fix problem
search the model number online,
search: (model# manual)
Aug 16, 2009 | HP (D7580-60003) Motherboard
YANG AN YA-1 E114139 94V-0.
The E114139 94Version 0 is an ABIT KD7 non-raid board
This link will allow you to download the manual, I would suggest the http site for download as some times the recommended site has errors.
Mar 30, 2008 | HP (D7580-60003) Motherboard
I want drivers for the motherboard: YANG AN YA-1 E114139 94V-0
Mar 28, 2008 | HP (D7580-60003) Motherboard
HP (D7580-60003) Motherboard Logo
848 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
