Question about Canon PowerShot A70 Digital Camera
Powershot A70 Have had the camera several years and always worked great. Went to download pix and this time the download program didn't pop up. Went to the program directly and tried and it said 'no camera recognized'. Have checked connections all seem ok. Pls help.
  • 1 more comment
  • mohalavt Sep 28, 2007
    Didn't work, now what, software uninstalled?
  • mohalavt Oct 26, 2007
    OK, that didn't work.  I do not see any other 'drives' other than c,d.a and scanner in my computer, should there be a drive showing for the camera.
    One other thing, when I turn the camera to the download setting the light flashes twice then doesn't again, unlike normal downloads where it continues to flash until the download is complete.  Help?
  • mohalavt Oct 31, 2007
    Have many important photos on this camera is there ANY way I can get them or try to get the camera fixed?
    Genius:
  • 2,985 Answers
Remove the Camera software. Assuming the camera is OK Windows ME/2000/XP/Vista will see the camera without software. Try it and come back
Posted on Sep 23, 2007
  • 1 more comment
  • john ash
    john ash Sep 28, 2007
    Software Uninstalled- OK
    This is a ME/2000/XP computer yes?
    Then with the camera switched on and operating and correctly plugged in Windows should put up the Scanner/Camera Wizard ask you what to do about the images.
    If it does not- with camera still plugged in etc., reboot the computer.
    OK now?
    No
    Go to my computer ans see if an additional drives is showing- that is if you have normal A C D drives then 'E' drive should show if you other drives then the next letter
    Come back when you have tried all that.
  • john ash
    john ash Oct 26, 2007
     This then is a camera fault on the main board.
    Actually- camera working or not the bestway to get images into a computer is through a card reader and not the camera.
    so 2 things - 1. junk the camera at this age no repair is likely
    and  2 when buying the next camera buy a card reader- they are quite cheap,
  • john ash
    john ash Oct 31, 2007
    There are several ways of getting images off a card.
    But it depends on your location and what exists there.
    Local processing station - here in the UK for example many large supermarkets and drug stores have them- you take the card in and either the staff there will do it and put them on to a CD for you or many are self service.
    Anything like that where you are?
    Or a friend with a computer that you can hook up to.
    The card reader already mentioned.
    Purchase another card to fill whilst the download problem is resolved.
    Coming back to the problem- from what you have said in the begining my response -   You will have to follow the adivce  to remove the card and get images off by the methods described.
SOURCE:
CCD problem with my PowerShot A70
Did you press the display button several times? To cycle through all the display settings, of which the display off is just one.
Jan 19, 2014 | Canon PowerShot A70 Digital Camera
Camera Canon Powershot A70) doesn't switch on
please first remove the battery ...it will create more damage to the circuit ....... repairing it depends on how much water damage has occured and even if repaired ...problems keep popping up ....
Oct 20, 2008 | Canon PowerShot A70 Digital Camera
I need a new USBcable to download pix from camera to computer
i would reccomend buying a card reader/writer for it as the cable wud be costly compared to the reader....
Oct 12, 2008 | Canon PowerShot A70 Digital Camera
Canon A60
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Aug 13, 2008 | Canon PowerShot A60 Digital Camera
Please read and advise
Hi
Just a question--have you made sure that the cord between the camera and computer is GOOD.The cord may be damaged,connections dirty,if there are pins-bent.Make sure this item is GOOD.Easy and simple things first and that which gets damaged any time and not looked at first.
Hope this helps
Jay
Oct 31, 2007 | Canon PowerShot A70 Digital Camera
Trouble downloading pics
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 14, 2007 | Canon PowerShot A70 Digital Camera
Powershot a70
Bad news is that this is a CCD sensor problem and you need a new one installed. Good news though is that Canon will fix this free of charge so contact them.
Sep 24, 2007 | Canon PowerShot A70 Digital Camera
Digital Display
if you can disassembly the camera and put it back again why not...but the problem is the ccd image sensor if you can buy it in the canon service center...that sensor is located at the center of the lens with a glass,square shape and have many pins..
Aug 25, 2007 | Canon PowerShot A70 Digital Camera
Problems when connecting Canon Powershot A70 - Cannot find program to upload pix
The popup would be the windows wizard wanting to assist with downloading image files. There's 2 popups one is the wizard and you'll click on transfer images & it walks you step by step to download the images. The other one is just a one click option & you can copy the images files to your computer. But since those options don't seem to work for you - one solution would be to click on "my computer" and you'll either find your camera or memory card listed along side your computers C drive. If you're downloading images from the camera - it needs to be hooked up via the cable + the camera probably needs to be turned on. Some cameras also have a setting or button to turn in order to download the images.
May 09, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
