Question about Ovens
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
Hi, our Whirlpool Super Capacity 465 model RF386PXE after it reaches desired tempature will often begin locking and unlocking for self-cleaning and an ER1 F2 code will appear. Rebooted circuit breaker but still occurs more than not. Can anyone tell me what the error code means and how to fix it? Big thanks in advance from Pennsylvania home!
  • 10 more comments
  • Anonymous Nov 03, 2007
    It's a small 27" oven. But when I've been broiling the F2 error code comes on. I turn it off and turn it back on and it seems to work ok then. What is the F2 error code?
  • brackish Nov 18, 2007
    unlocking/locking for self cleaning
  • Anonymous Nov 27, 2007
    On my super capacity 465 whirlpool oven, error code "LOC" appears. How can i correct this?
  • glinton1 Dec 08, 2007
    i was cleaning my oven and it locked on me it started smoking so i turn the power off please hlp
  • Anonymous Dec 11, 2007
    We bought a home , about 5 years old , that has a Whirlpool Super Capacity 465 self cleaning- accubake system oven. We would like instructions on how to self clean it. We did not receive a manual. Thank you for your help. J and D
    Our Jenn Air Wall Oven unit begins beeping and displaying an F1 and F7 once the oven reaches the preset temperature. I reset breaker and oven is fine until next time we use it. Any ideas?
    Thanks,
  • Joe Nova Dec 17, 2007
    Hi!
    My problem with a oven e1 f1 error on bipping like copcar!!!
  • Anonymous Jan 19, 2008
    when reached desired temp of 420 the f1 f2 error code came on and it kept beeping and flashing to turn off oven. ginger
  • doggyboy2 Aug 04, 2008
    I get an F2 error on my whilpool floor model stove
    Model # wdp68803
    Can anyone help!!!!!
    I'm locked out of my keypad.
    Dan
  • Anonymous Nov 05, 2008
    ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven problem,
  • icednavycop Dec 03, 2008
    Same problems . We moved into a new apartment with the Whirlpool 465 Flattop Burner (Electric). First thing is we get these error messages ER1 / F2. Second of all the over when we set the time and temp, we will watch the burners get red and then shut off. Then we get the error messages and it starts to beep. Even when we turn it off it still frigging beeps. Please can someone tell us where to find the manual online for this.
  • Anonymous Mar 18, 2014
    I SEE R1 ERROR CODE ON MY ACCUBAKE WHIRLPOOL 465 SUPER CAPICITY SELF CLEANING ELECTRIC OVEN.. WHAT DOES THIS MEAN?
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Posted on Nov 29, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced. if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! good luck.
Posted on Sep 28, 2007
  • 3 Answers
Http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ge&type=r
Posted on Jan 31, 2010
Tun power off, wait 5 min. and reestart.......done
Posted on Mar 30, 2008
6ya staff
SOURCE:
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
Don't have a appliance booklet for my Whirlpool Model 465 Super Capacity oven - need to know how to clean please
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Jan 06, 2011 | Ovens
OVEN TURNING OFF BY ITSELF. I THINK THE CODE ON IT IS SAYING F2
Hi!
The F2 code means Oven Temperature Too High. When this code is present do the following:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Whirlpool SB160PEE Gas Single Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
6,230 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
