Question about RCA R52WM24 52" HDTV Projection Television
Replaced flyback and cp-150 and now green light comes on for abou
It now comes on for about 5 seconds and thats it. before it came on 3 times for about 5 seconds each and therefore the suggestion of changing flyback and cp-150. any suggestions of what I might have done wrong or not done??
Thanks
  • waking2 Apr 22, 2009
    I have tried what you said bout trying diffrent power oulets and holding down on button and yesiget the flashing and a little sound for a second. . Have checked loose connestions . Cleaned it before I worked on it. I just noticed the back part of the circuit board is not flat on the bracket. Would this hurt anything ????
  • waking2 Apr 23, 2009
    The circuit board is not sitting flat . I ask you if this made a difference.? The back is not locked in. I can reset and lock in if this will make a diffrence.
    Brigadier General:
  • 8,619 Answers
Hi!
There is either a loose wire or loose connection on circuit board i.e. 'Power Circuitry' problem within the unit. There may also an intermittant component, or a bad connection on the printed circuit board. Switch off the TV, unplug it from the main power supply switch from the power socket and then try a different power socket. Do it two to three times. Also try this as well: press and hold the pwr button for several seconds, you'll get one flash, followed by nine flashes. Now clear the circut board with compressed air and make sure all the connections are secure.
Rremove all the paneling on the back and use compressed air to blow out all dust, and check that there is no burns, popped diods and fine circut board .
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 22, 2009
  • Rylee Smith
    Rylee Smith Apr 22, 2009
    Hi
    Thanks for your reply. As you said the circuit board is flat so you need to get it repaired/replaced as there is either a loose wire or loose connection on circuit board i.e. 'Power Circuitry' problem within the unit.
    Please do accept the solution and revert for further assistance.
    Thanks
    Rylee
My TV will not stay on...the power comes on and off 3 times and then stay off.
Problem will be in the Deflection board,Located on the bottom left handside it will have FBT flyback Transfomer on it, check Capacitors CP150, CP120, CP114. If CP 150 is Swollen or vented on Top the replace all 3 caps.2200uf 16v use 25v, 220uf 35v.
You ship board for repair to PTS 1-800-844-7871
These sets are also known for having Bad FBT flyback Transfomers and alot of Poor Solder Connetions
Jul 01, 2011 | RCA HD52W59 HDTV Projection Television
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Everything I read says if My GE Hdtv light is blinking 3 times and then going off it is the flyback. I just put a new one in. I took the board out and found CP 150 was domed real bad. Could this be the...
YES! THATS ONE OF THEM THERE IS 2 MORE IN SAME AREA THAT ALSO NEED TO BE REPLACED There is 3 capacitors 2200uf 16 v and two 220uf 35v they are Green with gold writing on them cp120 cp110? cp114,? cp150 Replace any capacitor that is puffed up on top.
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
Green light comes on 3 times and clicks and then wont come on.
replace the flyback, thats usually what is defective when the led will come on 3 times then go out. You need flyback 259296 which is very easy to replace. You can get one at the following link with free step by step instructions with pictures. Read the reviews on the flyback. Heres the link.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd52w59 won't turn on
Was cp 150 bad? bubbled up on top if so you have 2 more caps in same circuit that needs to be replaced they are cp111or cp120, or 114 each board has different # on location 2 caps will be 220uf 35 v, and one could be a 330uf 35v. Also when reconnecting second ribbon conector on deflection board, make sure it is in good or set will not come on
Dec 19, 2008 | RCA D52W19 52" Rear Projection Television
Flyback replaced
your flyback should still be good get the other parts changed out and go from there
Dec 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
Capacitors
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH74
the 3 blinks is definately meaning the flyback is defective. You need to replace the flyback its number 259296 you can get a replacement flyback at the following link with free installation instructions with step by step pictures of the repair. Heres the link.
Sep 30, 2008 | RCA P52937 52" Rear Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
