-   stop working after closing. Need to rebott computer to work again.-   Guest
Feb 08, 2008
-   My system had a virus and when I had my computer fixed everything was reinstalled except my sonic record now. So Now I have a cd burner that no longer works. What do I do.
Suzy93955@comcast.net-   suzy93955
Dec 12, 2007
-   Every time I reboot my computer, I'm faced with a repeated error message: HP Digital Media archive trying to use a network resource that is unavailable. Because this was pre-installed on my computer, I have no way to repair the problem. The file it is searching for is: ezarc.msi. This is driving me nuts!-   wifeofwarren
I know this was a year ago but if someone else has this problem then to let you know. If the software came preinstalled on the computer and your computer has a Recovery Manager you can reinstall the SW from there. Most computer manufactures started to using the recovery solution (an extra partition on the HDD) in 05 or 06.
If you don't have a recovery manager then the set of discs that came with the computer (before manufactures started using recovery solution) should have a applications disc. You can use that for a reinstall. If you no longer have those discs call your computer manufacture and they will be happy to sale you a set for $16 to $30.
Note: If your computer used the recovery solution then the only thing the discs can do is wipe your whole HDD clean and reinstall the original OS and Apps.
i have installed sonic record now and it is not installed though it does not show any problems..what...
(More)
i have installed sonic record now and it is not installed though it does not show any problems..what could be the reason. rn73dlx_16lang application was installed first and then the patch PatchGdiplus. The same download worked fine on another computer. What could ne missing in my computer so that it did not get installed. kindly help.
I have Sonic RecordNow 7.3...when I open it, it does not recognize my D: drive. It askes me to...
(More)
I have Sonic RecordNow 7.3...when I open it, it does not recognize my D: drive. It askes me to attach a drive but not is listed. How do I attach the appropriate drive?
My dvd shrink reads my drives but when i send it to sonic record now it say no recorder. Im not sure...
(More)
My dvd shrink reads my drives but when i send it to sonic record now it say no recorder. Im not sure whats goin on please help. Thanks, david sublett
