Question about SimpleTech SimpleDrive External 250GB 7200rpm 480Mbps USB 2.0 External (STIUSB235250FT) Hard Drive
The power on the simpletech 250gb HD keeps shutting off when idle i guess? im trying to backup some files that is taking a long time and when i leave it to do its business the HD stops and is unresponsive untill i start it back up and start the process all over again. same thing happens when idle for a while, ill come back and the HD is no longer visible on computer untill i restart the HD.
  • 702 Answers
Did you check the power settings? Make sure to not let the OS power down the disk at any time. Just check the Windows power settings.
Jules
Posted on Apr 23, 2009
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
Not enough memory to run time machine
If you do not have enough hard drive space to perform a time machine backup then you will need to either get a bigger external hard drive or delete files that you do not need.
Feb 29, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I backed up my entire computer on my SimpleTech Pinin Farina external hard drive and now I can't figure out how to find a file on it that I need. I see all the backup files, but I can't figure out how to...
Backup software compresses the files and encodes them to an image file made up of a series of sequenced files. The same software you used to do the backup should have the restore options needed to locate desired files. SimpleTech website shows Fabrik to be the name of the backup software.
If you utilized, there's also an online backup site used to store files. Following link is the users guide:
http://www.simpletech.com/support/guides/user-guides/60000-00168-001.pdf
Oct 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
I have SimpleTech drive that I used Storage Sync to back up C drive. Took drive to work and since all the files are 'bpa' cannot open them. I compare this to a simulation of what I bought the drive for -...
The BPA files are the backed up copies of your data. The simpletech utility backs up your files to compresse file ending in BPA. Any computer running the simpletech restore program can extract the data from these files.
You will simply need to install this software on a spare computer in order to test the backups. Frankly though I would just use windows backup to copy the files/folders you want to the drive raw as this can be read anywhere.
Hope this helps FixYa,
Chris
Sep 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
I accidently delete my backup software
I have been using Easy Recovery Professional for a while now and I have no complaints as to what it is capable of doing, you can download it at http://download.cnet.com/EasyRecovery-Professional/3000-2242_4-37386.html?tag=mncol OR you could simply download the Backup software at http://www.simpletech.com/support/support_downloads_storagesync1.42.php
Jun 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
I made a mistake and reformatted my SimpleTech Signature mini portable hard drive without first downloading the software to my desktop first before formatting..??and now I do not have the software that...
I don't quite understand what you're trying to accomplish. Do you want to try and restore the data that was formatted on the Simpletech drive? If so, follow the link and get a software program called recuva http://www.filehippo.com/download_recuva/ It's freeware. If you can't get it with that then there's another software program that I use quite often called Easy Recovery Professional. It's not free, but it's saved me quite a bit of time recovering lost files that I forgot to back-up.
Apr 30, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 3.5inch 250 gb wont start up.
Contact simpletech about a product replacement if you believe that the item is defective. I had the same problem and they had got me a new one FREE of charge.
Jan 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech external simple drive model 96300-40001-001--flashing blue light
do you mean that you used this as a "Data" drive and do not have the data stored on your pc...
that is basically the same as having no backup... if it is important, store the data in more than one location.
it is possible that a power surge killed the usb adapter on your storage device.... you may be able to transplant the HDD onto a working adapter or USB->HDD bridge to get your data back
Aug 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Restoring backup files
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
96 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
