F/L Washing machine doesn't spin
I have a Kenmore f/l washer, model no. 41743142200, that will fill but doesn't spin; it just hums. It will drain if I move the knob to final spin, but no movement. The belt is still intact
Normal 0 First drop the lower front panel and remove the pump so you can check the hose leading to the drainpump for debris, coins, etc.
Lower front panel has two? screws holding it in place.
Be prepared for water on floor... use shop vac or have several towels ready for water. Recommend putting at least one towel undermachine before removing pump.
Clamps that hold hose to pump can be a challenger to removeand replace. Consider replacing stockclamps with screw clamps.
This is a great fix.... did it last night.. Found coins, screws, etc. in pump. Once I cleaned out the hose area leading to the pump the spin cycleworked fine.
Posted on May 23, 2009
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Washer will not spin. it will fill then immediatly empty,3 time no spin or wash. belt is on, motor spins freely, the timer does move with cycle but fast kenmore 41743142200
this sounds like a timer problem, but need the make and model number to be sure, this model number will be on a on the rear panel of washer, or with the original owners manual.
Aug 17, 2010 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
My Washer machine fill up dosenl' spin
I think the problem is a faulty inlet valve that needs replacing. Hope this helps.
Jan 20, 2009 | Kenmore 24932 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
