Question about Mitsubishi VS-5043 50" Rear Projection Television
I have a Mitsubishi Model #VS5041 no parts available too old I wiped the finish off the screen yesterday any suggestions?? old parts?
  • fordcrazy287 May 07, 2009
    Thanks but I have no idea if the parts are interchangable had no suggestions on repairing this one I will keep you in mind if no other option I am in MO so it would be expensive to ship almost anything
I have the vs-45609. goes blank every once in awhile. maybe you can use it for parts for yours? in texas
Posted on May 07, 2009
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 11, 2015 | Mitsubishi LT-46144 46 in. LCD HDTV
My screen is broken need to find the part?
May not be available but try Mitsubishi---at shop where I work we save the entire screens with the frames on sets that get recycled.
Most 50 inch screens from a Mitsubishi set of that age will work just fine if you can find a used one---the larger ones are almost impossible to find used (60 and above in size)
You can also try to Google the model number with "replacement screen".
May 23, 2012 | Televison & Video
Unable to turn tv on and of.
if no parts is available have it converted, since it is only a switch. any switch will serve its purpose as long it has the same power rating
Jul 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mod. WS-655111 Fuse F9A04 & 05 bad. Set goes on & right off
You can order a replacement STK393-110 for this model (62HM95) from a major parts distributor at the link below:
Mitsubishi WS-65511 Replacement Part Convergence IC STK393-110
You would probably have to recalibrate the convergence after you install the IC. There may be a convergence kit available as well.
Apr 10, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
How do you replace the convergence part on a Mitsubishi big screen tv Model WS55511? The new part has prongs on the bottom and I don't know how to attach them.
they have to be soldered in place after you de-solder the old ones. Radio shack has a de-soldering iron with a rubber bulb that makes this easy. Then solder your new ones in use a pencil iron 30 watt also available from radio shack. Use heat sink compound on the back of the ICs where they contact the heat sink. This compound is also a Radio shack item. Just be careful not to bridge any of the pins together with solder. Check your solder with magnifying glass before powering it up
Jan 31, 2008 | Televison & Video
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
