Question about Nokia 3230 Cellular Phone
Poor signal suddenly got poor signal inside the house... while other phones are working.
    Sergeant:
  • 452 Answers
1. select network manaully. if still the problem is there then try another sim in this handset and try ur sim in another handset. u will come to know abt problem.
best of luck.
Posted on Oct 18, 2007
  • 89 Answers
Well. i think there is some problem with the mobile phone.i have the same phone and it's working fine one of my member in the house has samsung he has the signal problem in the house only all member of the house own nokia brand mobile phone and they never had any signal problem and even the people says that all i can say is that get your mobile checked with some one professional
Posted on Sep 30, 2007
SOURCE:
No Signal!!!!!
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 30, 2012 | Cell Phones
My LG thrill suddenly lost it's signal, and now
I had the same issue. A factory reset fixed it.
Dec 26, 2011 | LG Cell Phones
I have no network service
You may have : - Poor network signal ( Is your area has good signal?) - Broken SIM card ( Is your SIM crashed?) - Damaged Phone ( it could be some parts inside phone that not work properly)
Please investigate all above items.
Dec 17, 2010 | Samsung SGH-T349 Cell Phone
I am having signal problem
hi....
this is because the strength of the signal coming inside your house is less so the mobile is not picking up the signal.this is because of the walls and bulkheads surrounding the room which reduces the strength of the signal
thanx
Jul 13, 2010 | Nokia 5130 Cellular Phone
How can i gain some signal? Cause everytime i'm inside any establishment or in my house,my signal disappear.
you cant gain signal by yourself. many house places have this problem. try in different location to get signal..
Its a common issue . its not your phone fault if you could get good signal in outdoors
Jun 20, 2010 | Nokia N79 Cellular Phone
The County Sheriff broke my door down while I was not home. Left a John Doe Search Warrant on the table. They tore my house apart but didn't take anything. Mine and kids' Laptops were with us, but now we...
> can't access 'net through router
When you "view available networks" on your laptop, do you see the SSID for your router as being present? What's the "signal strength" (poor? none?)
Have you tried powering-off the router, waiting a few seconds, and then powering-on the router, and then retrying on the laptops?
Have you tried an Ethernet cable directly between the network-port on your laptop and one of the LAN ports on the router? That should give you a fast connection, because it is not "wireless".
> cell phones all drop calls
Weird. Did they wrap your entire house in metallic foil, to "block" signals from the cell-phone tower to reach inside your house, to your phones?
If not, why has the signal-strength dropped so much?
What happens if you take your cell phone just outside your home? a few houses away? a few blocks away? a few miles away? Does the signal-strength increase "sharply" at some distance?
With your cell-phone, walk all the way around the outside of your house, to see if there is a "good" side or a "bad" side. Repeat on the inside, and see if you can draw a "map" (4 bars here, 1 bar there).
Apr 09, 2010 | Computers & Internet
No service inside house
hi there,
ABout the signal of your cellfone, this can be a weak signal from the network or the location inside your houise wasa death spot, cause of thick wall and roofing.
you may need a Motorola 270c MINI Magnet Mount Cell Phone Antenna Booster.
Mar 12, 2009 | Motorola Cell Phones
Call restrictions -34 everytime i try to make call with my cell
Restrictions -34 Is No signal Went outside my house works fine.Found that I had Poor signal in my house
Dec 02, 2008 | Lands Phones
I cannot use my cell phone inside my house
check for interference from household appliances
check the material used in the house cladding as it may be blocking the signal
indicates an environment problem in the house as different phone makes are in use and the only common factor is the service provider
you may have to pay to get a technician in to the house to measure the signal strength from the cell tower inside your house
if you have any electronic vermin plug in units in the house try switching them off as they work at a frequency that may be affecting the performance inside the house
Jul 18, 2017 | RIM BlackBerry 7100G Smartphone
Poor signal
u must get it normally serviced
Apr 25, 2008 | Nokia 5200 Cellular Phone
Nokia 3230 Cellular Phone Logo
156 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
