This is a electronic hardware issue
Looking for the manual for programming a digital panel meter made by Colluck model # PM328 Thanks Rob rpustizzi@ueonline.com
    Sergeant:
  • 400 Answers
Mailto:mpja@mpja.com?Subject=Meter Warehouse Web Contact
Posted on Jul 26, 2009
Looking for electrical testing meters
"METER" Question
leaves a WHOLE lot open to interpretation...
If you are looking to see battery at the BATTERY itself ...
or even a TAIL LIGHT...
Garden variety METERS might be a SAFE way to go...
(REMEMBERING... the
slightest mistake = air bag DEPLOYMENT (explosion)).
but... (and this is a BIG but)
You CANNOT use ordinary "METERS" on
>> sophisticated electronic / semiconductor equipment...!!
Base line: Only HIGH IMPEDANCE PROBES ...
(LOGICALLY imperceptible) can be safely
( perhaps even effectively )).
OBD (on board diagnostics) have been STANDARIZED
over the past couple of decades to report in INDUSTRY
acceptable DTC (diagnostic trouble codes)...
Behind that... there are the COMPLETELY PROPIETARY
(property)... firmware/software EXPRESSLY owned
(for example VW) with only USER privileges extended...
(right to use) to any/all of their customers.
In the fine print of EVERY RTU I have read in my
extensive careers in STORED PROGRAM CONTROL..
"REVERSE ENGINEERING" has always
(consistently & completely) been FORBIDDEN...
(with Brigades of ATTORNIES to ENFORCE
(or defend... depending on what/who gets damaged)).
So... as to your question about "METERS"... (et al)
Typically those cheap/FREE/promotional digital
meters given away to attract customers to
HARBORFREIGHT (for example)... can be used
to check SUPPLY volts, amperes & ohms...
are completely acceptable...
So LONG AS YOU KNOW EXACTLY WHAT
YOU ARE "METERING"... (in my humble opinion).
And as ALWAYS... Wear your anti-static wrist strap
every-time you handle ANY semiconductors you
care about (ESD - protection: see below).
ELSE
Expect to be purchasing ($$$$$) expensive
electronics... and AIR-BAGS.. Savvy?
Firefold
https://www.firefold.com/tester-digital-clamp-meter
Harborfreight
6 Function Mini Digital Multimeter
Search results for volt meter
ESD ($6 Static Wrist-band)
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Carnac the Magnificent
Jun 07, 2017 | Cars & Trucks
We had an electric outage last night and now our Intermatic Digital Timer Model PI353ME for our pool will not work. What can we do?
Try the small round reset button top left, and then re-program:
Manuals, including troubleshoot pdf, and wiring on following link:
http://waterheatertimer.org/Digital-control-centers-and-manuals.html#PE153
Install type 2 whole house surge protector or type 1 surge arrester to protect timers, lights, electronics. Make sure household grounding is appropriate, bond outdoor equipment to a ground wire that goes into dedicated ground rod:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Dec 18, 2016 | Intermatic Hardware & Accessories
How do I diagnose a fault with electronic meter?
Hi, Steve for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Error Codes
http://www.electrosport.com/technical-resources/known-issues/common-tech-issue?model=607
http://www.groussin.com/multi/XV250.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Aug 03, 2014 | 1989 Yamaha Xv 250 Virago S
I am looking to program a Toshiba television for digital tv.. the model number is MW24FN1
If your Toshiba TV does not require a converter to receive digital signals, you select the setup routine and search for available channels
Jun 23, 2013 | Toshiba Televison & Video
Where can I find manuel for model 681 DQ 63
http://www.healthometer.com/Manuals.aspx
^ This should be what you're looking for. Click the second link that says "Wt. Tracking & Body Fat" and then click the "BFM.." link. You need adobe or a similar program to open the .pdf file. This shouldn't be an issue but if you can't open it, you can download adobe here: http://get.adobe.com/reader/
Mar 12, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
I am looking for the manual that would tell me how to reset the codes in my keylsee entry locks
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Dec 28, 2010 | Schlage Locks & Locksmithing
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
