I have a IR5020 set up. It works fine as a copier. It has a network card installed and going into the network setting is has a IP address and subnet mask. I also can bring up the controll panel by intering the ip address into my broser. I am on an XP Pro machine, 32bit. I can not see the printer while trying to configure the port.
    Genius:
  • 1,847 Answers
Download the latest version of the drivers and then try again...
PPD Installer v2.50
PCL5/PCL6 Printer Driver v8.35
http://www.canon.com.au/products/multifunctionals/multifunctional_digital_devices/iR5020_drivers.aspx
Let me know ..
Thanks
K
Posted on Apr 22, 2009
Set up wirelessprinter hp
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Jan 28, 2013 | Office Equipment & Supplies
How to enter an IP address on a hp2035n
To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0
Jul 17, 2012 | HP P2035N LaserJet Monochrome Printer
Installed on a network....keeps rolling IP
If your network is assigned by DHCP have a chance after each shut down your printer will take new IP address...you can set up IP address manually from printer menu using buttons on top.
Just print menu map to see where you can find that option.
Apr 28, 2010 | HP LaserJet 2420dn Printer
I am on a network with a brand new HP 8500. I have searched for the printer and my laptop doesn't pick it up. What amI missing?
Have you checked that the IP range for the printer is on the same IP range for your network? you could always cold reset the printer which will reset the network card back to zero's. You attach it to the network and your server should issue an IP address via DHCP. You should be able to see it on the network then.If not, the jetdirect network card may be at fault.Has the printer got a Jetdirect network card installed?
Oct 15, 2009 | HP LaserJet 8500 Color Printer
What drivers are needed to work a canon imagerunner 2200?
Could you print before reinstalling Windows? I assume you could in my answer below.
Try pinging the copier from your computer. Go to Start > Run > CMD > ping 192.168.0.5 - t
Replace 192.168.0.5 with the IP address of your copier.
Open the RUI as suggested above e.g. http://192.168.0.5
Can you use Canon Network ScanGear Tool? (Google it, it's freely available from Canon website and comes with user manual).
Make sure that your copier has the same IP range (first three numbers out of four for IP address are the same) as your computer and that the subnet mask's are the same e.g. 255.255.255.0.
Go into Additional Functions > System Settings > Network Settings > TCP/IP Settings > IP address to check these on the copier. Make sure DHCP is off (DHCP box should be filled with white, not filled in with black)
Where the network cable is plugged in can you see two lights coming out through holes? Move your head, they may not be immediately visible. If not then the network card isn't working.
Have you tried hooking up a laptop to the copier via crossover, changing IP address settings on both copier and laptop and seeing whether printing works that way.
Try turning off firewalls etc and see if printing works. If turning off firewall fixes it, turn it back on and add the copier's ip address as trusted.
Have you tried changing ethernet cable, seeing whether you can print from another computer on the network etc. If it works from another computer on the network you could share the printer or check how it's setup on that computer and copy the settings.
Set up the printer as a local printer. Set up a TCP/IP port with the IP address of the copier and use the PCL5e/PS drivers. If using PCL5e select print as image in the settings and if options installed are not immediately recognised press get device status, change settings as required. Set output paper size as A4, Legal or whatever you want not "Match Paper Size"
When you print check the copier to see if an error comes up or anything. If it comes up with an error to load paper select the paper tray you want and it should print.
If you couldn't print before reinstalling Windows do the following:
Press the counter check button. Near the bottom of what comes up you should see 2200(2200N). If you don't see the N then it's not networked properly.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Look at BOOT-ROM, it should have a N at the end of the number. There should be a number for PS/PCL. If there is no number for PS/PCL get a tech to come and reload firmware so you can print.
Apr 22, 2009 | Canon imageRUNNER 2200
Scanner installation
I WANT T INSTALL SCANNER SOFTWARE IN MY SYSTEM
Dec 09, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Networking Copier
Was a new set-up on the network done??, its probable you have new ip addresses and the 1430 has to have a static ip address to function... therefore it is likely a new set-up/installation would have to be done.
Oct 04, 2008 | Muratec MFX-1430 Copier
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Printing connected ethnet set ip address wil not print
Go into Additional Finctions, select Network Settings, input IP Address, or select DCHP. Connect to PC or network. Download relevant printer driver. Switch photocopier on/off. Everything should work ok. Let me know?
Nov 30, 2007 | Canon imageRUNNER 2200
78 people viewed this question
jasbo
jasbo
