Question about Toshiba DR410 DVD Recorder
Hello with mine (DvD player SD-190ESE) I versendtlich it menu which adjusted and now no picture has however clay/tone and I do not come no more into the menu option purely. One can do it Reseten.
    Sergeant:
    Champion:
  • 255 Answers
Setting it to factory default can fix this.
Posted on May 20, 2009
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
We have reconnected our DVD to our new flatscreen and can see the picture, hear the sound but the picture is only black and white
This sounds like either the colour settings on the DVD are wrong for your new TV, or the TV has got the wrong setting for the socket that the DVD is connected to.
Go to the menu of the DVD first and look for picture settings etc. Or colour, keep your eyes peeled for the words PAL or NTSC.
Feb 06, 2010 | Toshiba SD-K770KU DVD Player
Attempting to play a DVD on a Toshiba player but not able to get full screen picture on TV. Can you help with the problem?
A DVD plays in "Letterbox" format. To have full screen, the TV settings need to be changed to full screen, or zoom. Found in the TV menu of most TV's.
Read ya
Z
Dec 31, 2009 | Toshiba SD-K760 DVD Player
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
I need to program a universal remote for a Toshiba SD-K510.
it is 1110 the code for Toshiba SD-K510 it works on mine Toshiba SD-K510 the code on mine universal remote
Jun 07, 2009 | Toshiba SD-K510 DVD Player
A toshiba SD-37VSR DVD player that the TV will not recognize
if you are using the hdmi or DVI ports you need to make sure that both the player and tv are HDCP compliant (it will say on the box usually) otherwise, try using a different output from the player going into the tv. (try the composit or component instead of the digital outputs)
May 26, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung 6768W DLP 2 yrs old Replaced lamp and now color is off Faces look like paint by number
possible solution:
http://www.avsforum.com/avs-vb/showthread.php?t=1050735
  1. You may need to adjust the index delay after the replacement. You will be able to tell because you may see strange color banding in any scenes that have colors close, but not quite the same, in tone. This is usually most obvious in face skin tones (i.e. “clay faces”). If you need to adjust index delay, turn off the set, wait for the lamp to cool down, then hit mute-1-8-2-power in succession. The set should turn on with the service menu popping up eventually on the left. I don’t remember which submenu “index delay” is under, but find it and usually it will need to be lowered. I believe mine started out in the mid-50’s and had to be lowered to 47. These numbers are different for each Samsung model, so just adjust until the picture is pleasing to your eye. By the way, the supposed “correct” way to do this is to make the reddish part of the test color bar appear the “most saturated”, if you have a color calibration device.
Oct 15, 2008 | Samsung HLR6768W 67" Rear Projection HDTV
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Toshiba DR410 DVD Recorder Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
