Question about Sunbeam Oster 4094 2-Speed Blender
How do you remove the stud for blender 4073-94
  • Anonymous May 09, 2009
    i would like how to remove, also.
The drive stud on my vitamix 3600 blender sheared off. When screw is replaced it comes unscrewed when the blender is turned on. Does anyone know if the original design included epoxy weld?
If the motor runs in reverse to an Oster which uses counter clockwise thread then it follows that your thread should not be counter clockwise. If it comes loose when you turn it on surely the thread on the coupling must be faulty because according to your description the action of turning it on can only be to tighten the coupling. Most couplings with a thread that I have seen are counter clockwise so you will probably struggle to find another brand coupling to match.
Feb 28, 2015 | Vitamix Blenders
How to fix the blender,the motor works ok but the blades don't move
check to make sure the drive stud is spinning with the motor. If it is, make sure the blade assembly is lining up correctly as well as fitting tight on the drive stud. How to Repair Blender How to Repair Small Appliances Tips and Guidelines
Dec 09, 2014 | Oster Blenders
Does anyone have a schematic showing how to put the motor back together. mine was taken apart, and now I can't find the washers and need to replace and put everything back together correctly. any help...
follow this steps . God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
Nov 24, 2013 | Waring MBB518 2Speed Blender
I'm using the single serve mixer and it's stuck on the base and won't come off!
follow this steps and fix it. God bless you
Nov 04, 2013 | Blenders
Remove stud drive from blender
You have to use a flat edge screw driver for locking the motor shaft.
first you put the screw driver to the slit on the motor shaft at at the bottom side at the same time you should use suitable wrench for unscrewing the stud
I hope this helps
Mar 30, 2013 | Waring 502696 Drive Stud
Can not remove base from blender model BL5500SC
leave the blender jar on the blender. with one hand grab the glass jar handle with the other hand hold the base of the blender. then twist or push the handle counterclockwise to free it up so you can completely remove it from the blade
May 19, 2012 | Blenders
How replace Drive Stud & Slinger Pin part
No need to:
- cut the washer or
- remove motor
Hold washer w/ vice grips and turn stud counter clockwise with box end wrench, small crescent wrench, or another vice grip. Should turn fairly easily at first then finger loosen. A 50y/o model 541 continuously exposed to salt sea air gave no resistance at all w/ this method.
Aug 02, 2011 | Oster 006832000000 10Speed Blender
Hi, my blender blades won't turn on i have cuisinart blender 7 speed plz help
when the blender cup is not on, does the spindle turn (medal stud looking thing)
and does it do it on all speeds?
Aug 12, 2010 | Cuisinart SPB-7 SmartPower Work Top...
Motor just buzzes will not rotate tried new capacitor,no help
you may have a loose coupling or drive stud. These are the items just below the jar. you can use a pair of pliers and tighten the coupling or drive stud. If it is not just loose, but stripped, you will need a new one. hope this helps
Jan 12, 2010 | Blenders
Sunbeam Oster 4094 2-Speed Blender Logo
206 people viewed this question
Top Sunbeam Blenders Experts
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sunbeam Blender Expert? Answer questions, earn points and help others
