Question about Whirlpool Duet GHW9150P Front Load Washer
Duet large capacity electric washer with matching gaz dryer on a
How do i get to the pump and filter my unit is mounted on a pedistal
Getting a error F 9
You should just be able to take off the front bottom cover three torx screws.
Posted on Apr 23, 2009
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I keep getting a dL and then a code F on my washer
LD = Long Drain ErrorRemove the 3 screws on the bottom kick plate, remove the kick plate. You will see the pump filter on the bottom right had side. Open the filter and remove any debris.
Feb 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
We have a whirlpool duet washer/dryer. We are getting an F2 error which occurred during spin cycle. Have checked the hose and it is free of any clog, etc. It sounds like the pump is just humming. Where...
Hi
Error F2 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting the code f21 on my whirlpool duet washer and the door willl not open
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
May 18, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do I remove the pedestal from whirlpool duet washer and dryer
The unit simply sets on top of the pedistal on the newer style.
Lift off the unit to separate the 2.
Nov 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing f11
Hi
F11 is a Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Please do rate the solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
    How to remove pedistal from machines
    lay the machine on its back. unbolt the base. 4 bolts. then set the duet back up. Its pretty easy to do but it takes two people to man handle the unit because it is so heavy. Please leave feedback if this helped.
    David
    Jan 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
    Attach pedastal to whirpool duet washing machine front loader
    you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
    Thanks,
    David
    Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
    Need help
    This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
    Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
    AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
    Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
    Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
    Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
    Item Features:
    • Super Capacity Plus - 7.0 Cu. Ft.
    • AccuDry™ Sensor
    • Senseon™ Drying System
    • 8 Automatic Cycles
    • Bulky Items Cycle
    • Adjustable End-of-Cycle Signal
    • Wrinkle Shield™ Plus Feature (120 Min.)
    • 5 Temperature Selections
    • Quiet Dry Plus Noise Reduction
    • Dry Rack
    • Reversible Side-Swing Door
    • Dryer Door Window
    • Reversible Side Swing Door
    • Electronic Controls
    • Front-Mounted Lint Screen
    • Interior Drum Light
    • 4-Way Venting
    • Porcelain SpillGuard™ Top
    • Optional Storage Pedestals Available
    • Stackable Installation with Matching Washer
    • Matches Duet® Washer
    Specs:
    • Warranty: 1 Year Parts & Labor
    • Capacity: 7.0 Cu. Ft.
    • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
    • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
    • Controls: Electronic Controls
    • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
    You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
    Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
    Whirlpool duet front loading washer purchased in 2004, beeps and displays F9 code during whitest white cycle or heavyduty cycle when washing towels, this provokes unusual delays, frustration and ineff
    Boyz, your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer stops and generates this fault code. Here are the things to check; * Check the drain hose and make sure it is not plugged or inked. * Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) * Check/Clean Drain Pump Filter of foreign objects * Check for Drain Pump Failure * Check the Inlet Valve for proper shut off * Check the Pressure switch for proper operation
    Aug 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    46 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
