Question about Mackie SWA1501 Subwoofer
Mackie srm450 not making any sound at all
Was using my mackie srm450s at a party had them playing quite loud they both overheated and the internal red thermostat light came on so they stopped working. Let them cool down and rest for a good while now one them wont make any sound at all. It has all the normal working lights which come on (blue led on front, green on back plus the flashing green led which shows its receiving signal input) however no sound at all. Im really confused as to what the problem is any help would be very greatfully recieved.
Antoine
  • saintslash Apr 22, 2009
    ok well i am certainly no expert at these kind of things only problem is i dont have a warranty and im worried that im gonna be charged loads of money, also im in the uk and the closest service place for mackie actives is about a 2 hour drive away, do you think this would be a long job for a technician to fix?? is there any simple way of checking these problems?? cheers again mate, Antoine
    President:
  • 1,489 Answers
It sounds like the thermostat didn't shut the speakers down before they were damaged. There is probably a very fine wire leading to the speaker coils which is burned/broken. Fixing this broken connection my solve the problem unless the coil itself is damaged.
Another possibility is that the crossover circuitry in the speaker cabinet is damaged from overheating.
Sounds like you need a service tech to look at the bad speaker, unless you want to tackle the job.
Posted on Apr 22, 2009
  • Samuel Charles Spriggs Apr 22, 2009
    Antoine,
    About the only simple check you could perform is to take the speaker cabinet apart and visually check to see if any wires are burned & broken. If there are, these could be spliced to see if that's the only damage. This is very tedious work especailly if the wires are very fine.
    It wouldn't be long job for a tech, but their rates are pretty high -- my guess (and that's all it is) is a coupla hundred dollars.
    Charlie
Blown Mackie srm450 woofer makes sound but rattles when turned up
I need more information, but some similar event i remember with SRM450 and was the paper cone on the speaker, not visible from outside but inside was severely cracked all round, hope this helps.
Apr 23, 2012 | Mackie SRM-450 System
What size internal fuse on mackie srm450v2 speaker
Mackie say this is not a user service part. If the fuse has blown there is probably a fault in the unit being their reasoning. I know for certain they tend to blow for no apparent reason so it is worth giving it a go. They are 5 x 20 Slow or time fuses. 7A for 120V and 4A for 230V
Jul 13, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
Hi I have a pair of Mackie SRM450s. When applying power I get a high pitch squeal whether I have speaker leads connected or not. After flicking the low cut or contour buttons on and off it then goes away....
Make sure you have ALL interconnected parts of the system powered from the SAME receptacle or power conditioning module. This MAY require you running an extension cord back from where your speakers plug in to supply power to the mixer. The ground bounce in power wiring in building can cause feedback or even destroying the sensitive input circuits of your system. As an electrical engineer I see these problems frequently. I think they should include this information with sound equipment user manuals, but they don't and people have trouble and damage their equipment. Doing this MAY also fix the problem you are having.
Apr 16, 2011 | Mackie SRM450 V2 Active DJ Powered Speaker...
We use a mackie dfx 12 mixer and 2 mackie srm450 active speakers for a band situation the mics are sure sm58s we have to keep the levels of each cannel mixers quite high what are we doing wrong
Does the VU-meter (green/yellow/red strips of LEDs) on the mixer go all the way to the top when you adjust gain and slider level?
If yes, try boosting up the active speakers by adjusting the small volume button at the back of the speakers.
Also, make sure the equalizer (on the mixer) is set at 0 (the middle) for every slider (And not at -12). The 'voice cancellation' and 'break swich' should also both be unpressed.
Dec 13, 2009 | Mackie SRM-450 System
Mackie SRM450 speaker keeps making a 'popping' sound
First thing is to verify that a ground loop from your driving equipment is not causing the problem. Easiest way is to drive it with a BATTERY operated little CD player so no ground loop could exist.
Verify that your power cord is in tight and try another cord to verify it is OK.
Beyond this, service is probably required. If unit is out of warranty, you could have a person open it up to see if anything is obvious.
A possible proble is bad connectors or worse, a cracked circuit board.
Analyzing if noise is from both the woofer and high range speaker is a first step.
Aug 31, 2009 | Music
Repair a Mackie SRM 450 Speaker The Speaker is making a crackling sound while playing. The sound keeps cracking up.
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Jul 20, 2009 | Music
Mackie srm450 the tops on one speaker is not working
Hi There, This is quite a common problem with the Mackie SRM450's. You will find that you need to replace the diaphram on the top. This can be done by removing the 16 screws from the back of the Mackie (quite a long pain in the **** job) with a long handled cross head screw driver.
Once you have done this you should then remove the hex bolts from the back of the drive where the black and right terminals are. When this is done, pull off the cover and swap the diaphram out. With the new diaphram in place reverse the steps above but before you screw the back on, power it up carefully and check the sound is now working.
If the diaphram keeps going eg every 3 to 4 months then you will need to change the driver which is quite expensive to do. If you need spares and are based in the UK, contact LondonSpeakerShop.com who carry spare parts or can undertake the repair.
Hope this helps.
Feb 22, 2009 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
508 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
