Question about Dynex 32 in. LCD Flat-Panel HDTV
Clearence between tv an wall
I'm Mounting A 32" LCD TV to A wall in a RV.How much clearence do I need between the TV and the wall. I'm makeing my own wall mount.
  • 431 Answers
You need at least 25mm so as to allow the circulation of air around the unit , any less and you risk the unit overheating .usually the mounts protrude this far and don't cause a problem . ... Regards Vortash
Posted on May 01, 2009
Mounting on the wall
Yes, you need to purchase a TV wall mount for that size tv. Best-buy, costco, sam's club all sell them
Mar 07, 2014 | Envision L32W761 32 in. LCD TV
How much does this TV weigh? Is it considered a 32" when mounting on wall or do you considered the entire diagonal at 38"?
The TDA-03211c weighs 39.5 pounds; however, I'm not sure if that is with or without the base. The shipping weight of the TV is 50.3 pounds. Most wall mounts use the standard screen diagonal measurement to determine what size TV it will support. So the 32" is sufficient information for choosing a wall mount.
I hope this helps.
Nov 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
What is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Sep 25, 2011 | Televison & Video
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
What size screws for wall mount
Metric M5 or M6, you can get them from ACE hardware, HD, or Lowe's for about 20 cents each, the length will depend on the thickness of the mounting plate, by the way, when you buy the wall mounting kit, it will come with a bag of screws for mounting the TV to the bracket.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Akai LCT3285TA 32 in. LCD Television
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do I mount my Soyo MT-SYTPT3227ABMS on the wall
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Aug 03, 2010 | Microsoft MT-SYTPT3227AB 32 in. LCD TV
Bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
http://s807.photobucket.com/home/budm/allalbums
Jul 04, 2010 | Sylvania LC-321SS9 32 in. LCD TV
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Dec 18, 2009 | Proscan 32LB30QD 32 in. LCD TV
I NEED A WALL MOUNT FOR A 32" tv
Wall mounts use standard mounting configurations, you should be able to get a wall mount for a 32" flat panel TV at any local electronics store.
Jul 30, 2009 | Element Electronics Televison & Video
Dynex 32 in. LCD Flat-Panel HDTV Logo
105 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
