Question about Garden
I have a kawaski 17 hp engine on a ,John Deere lawn tractor, engine code FC540U-ES00. The engine is hard to start, the warmer the engine gets the harder it is to start. Also the engine backfires when shutting it off.
  • Anonymous May 16, 2009
    I have same engine and tractor. Engine starts okay but has a single backfire when it is shut off. Any solutions?
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
JD 68 riding mower
dear sir
tour bottom end is going in your lawn mower or tyoyur block is cracked. sorry but thats the truth.
May 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
