Question about Craftsman Garden
Craftsman leaf blower, primer bulb will not return, won't start
Craftsman leaf blower, primer bulb will not return to normal once pushed in, carb has been cleaned, all fuel lines have been cleaned and checked. when fuel is dumped directly in, it runs fine.Diaphram in carb does not appear to have a hole in it. has walbro wa219c carb. Should i replace carb and bulb?
Primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
    Problem Solver:
  • 6 Answers
It sound like the primer bulb does not retract by itself due to aging problem.
Posted on Jun 18, 2009
On mine the problem was a clogged in-tank filter. This prevented the primer from being able to **** fresh gas into the bulb.
Posted on Oct 29, 2012
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Hello, I have a sears leaf blower (358.794762) that will not start. It's almost like the primer bypasses the carb
Sounds like your fuel filter is plugged. Bend a hook on a piece of wire and fish the filter out of the fuel tank. Remove the filter and see if you can blow through it. If not replace the filter. Good luck.
Nov 19, 2015 | Garden
Ryobi instruction manuals
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Pump bulb on craftsman weed blower and no gas pumps into the bulb
If you slacken the screws fuel will leak as you have broken the seal between the carb body and the primer bulb so this is quite normal, behind the bulb is a plate with a red non return valve, if this valve is faulty it will not pump fuel, or if the filter in the tank is part blocked it will not pump fuel
Aug 26, 2012 | Garden
Just replaced carborator and now it won't start. any suggestions?
you might have primer bulb lines on backwards or the gasket between carb and motor is upsine down
Aug 25, 2012 | Craftsman 2 Cycle 25cc Handheld Leaf...
Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 17, 2009 | Craftsman Garden
I am replacing the fuel tank assy and purge bulb (i.e. primer) on my Sears Craftsman model 358.798940. The original plastic tubing was old and brittle and broke apart while disassembling, so I could not...
The order of fuel travel should be:
Fuel filter to fuel hose to Carb's Fuel Supply nipple. (On the main body of the carb)
Primer Plate Nipple on carb to fuel hose to Suction Nipple on Primer Bulb. (It must pull fuel thru the carb, not push)
Pressure Nipple on Primer Bulb to fuel hose to Fuel Tank Return hose.
When correctly installed, the fuel will be PRESSED into the fuel tank via the return hose when primer is pressed in . . . and SUCTIONED out of the tank and into the Carburetor when primer in released.
Hope this helps,
Dolf-
Oct 16, 2009 | Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
4,094 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
