Question about Aiwa PX-E860 Turntable
Aiwa PX-E860 turntable
Hi my turntable won't seem to turn on anymore. Electrics are ok, can you help?
  • madwife Sep 25, 2007
    Hi...
    It is the Transformer, i think the Main Coil shorted...but what i can't seem to find out is whats the voltage output?? Ive seen the Transformers in Maplins for around a fiver, but they have 4 varying outputs from 6v 9v 12v and 15v....ive looked on a Service Manual on line and it only tells you incoming voltage of 240V not whats after the transformer.....HELP!!!
  • 515 Answers
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Posted on Sep 24, 2007
Did u check the belt
Posted on Aug 31, 2008
SOURCE:
My Aiwa px e860 record player arm is too heavy how do I adjust it?
If you put the maker and model number into Google you will find a service manual free for the make. That should help you sort out the problem. It's just a question of getting the weight at the other end of the arm adjusted right.
Dec 11, 2016 | Aiwa PX-E860 Turntable
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Can the aiwa px e860 be run independently from a hi fi unit
You would have to make an independent power supply for it. It would help if you can find the system service manual. This should show what the power supply line is. You could then build a power supply. Generally these system turntables don't use one greater the 12 volts DC, and there are power adapters pre-built that would do the job. But you would need to adjust the voltage to get the speed right.
Jun 21, 2014 | Aiwa PX-E860 Turntable
How do I remove the stylus of an Aiwa PX-E850 Turntable?
Hi, grip the stylus between thumb and forefinger. Then in a pulling down and forward motion remove stylus. Cheers john. Stylus City
Apr 02, 2014 | Aiwa PX-E860 Turntable
THE PLASTIC COVER OR LID IS BROKEN FROM MY AIWA PX-E860 TURNTABLE WHERE CAN I BUY IT. SILVIA DE ALBA
I don't think you can find this part easily and new and honestly it doesn't worth it.
I would suggest to go for this or something similar
Aiwa Stereo Full Automatic PX E860 Turntable System
Feb 12, 2014 | Aiwa PX-E860 Turntable
On my Aiwa PX-E860 the automatic mechanism is failing - when i thry to manually place the stylus the platter does not turn - is there a way to by pass the automatic part and just have it manual?
Select the record speed.
Press the 2 down arrows or triangles( placed side by side) - This the same thing you press if you want the styles to lift during play
Place the stylus on the desired spot.
Press the same button again.
The stylus will drop to the desired spot & continue playing
If you have the manual look it up, else download one from this site after becoming a member(its free)
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Nov 30, 2010 | Aiwa PX-E860 Turntable
I need a motor for my aiwa px-e 860 turntable
Hi, stylus city can supply a motor for this turntable. [email protected]
Jun 23, 2010 | Aiwa PX-E860 Turntable
PX-E860 Turntable: I need to replace the cartridge of my aiwa turntab...
my aiwa PX -E800 TURNATBLE has stopped working ,, is there anywhere i can get a replacement turntable .
Regards
Trevor
May 17, 2010 | Aiwa PX-E860 Turntable
Aiwa PX-E860 Turntable Logo
570 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
