Question about Avermedia QUICKPLAY (pquickplay)
Avermedia Averkey lite - Monitor Colour Display Issue
Hi.. I am able to get my PC/Laptop display on my TV, but it appears in black and white. I have used Notepad + Monitor display setting and it works fine. Also, I am using 1024x768 resolution as instructed in one of the solution. I am unable to get colour display in my TV monitor alone. Pls advice me with a solution to fix this issue. Appreciate your quick response.
I had the same problem. I was going from PC -> Dvd recorder -> TV.
I had the S-Video output from the averkey going via an adaptor into the DVD scart input. I discovered a setting within the DVD menu which could select between 's-video' and 'composite video' on the scart socket. (it appears that scart can carry either/or, I guess).
I changed from composite to s-video, and I got colour.
I think seeing a greyscale image indicates that the signal being sent is S-Video, but the equipment that is recieving it is expecting composite video.
Posted on Dec 07, 2007
"Guests" solution worked exactly in the same way for me. Thanks very much.
Posted on Dec 12, 2007
SOURCE:
I am trying to hook up an averkey to a laptop and TV. I have the TV set on video-1 and I have used the FN -F7 keys several times but I still do not have a picture on the TV and the red freeze light...
Check the resolution you are outputting to the TV and check the resolution the TV is set to. These must match for the TV to display properly.
I hope this helps
Aug 31, 2011 | Avermedia AVerKey 300 Gold (61K0C3BF)...
Acer aspire 3680 svideo in black and white?
Have you checked The Settings in The Bios.
Your laptop May be set As NTSC Or PAL, displaying on A Different format tv set ?
Try An external Monitor, Or the TV Out if applicable.
If these work in Colour rather than monochrome ( Black And White ) then the fault lies with your svga output on the laptop.
Mike @ compurepair.
May 07, 2008 | Acer Aspire 3680 Laptop
Averkey
Unit powers up but will not show a picture on the TV. Was working previous day. I have check all cords and even replaced them with ones from another averkey but still no picture.
Apr 02, 2008 | Avermedia AVerKey Plus (AVERKEY-PC)
BLACK AND WHITE PICTURE
Verify that your region setting is correct, ie USA is NTSC.
Please let me know if this works for you.
thanks
Jan 18, 2008 | Avermedia AVerKey iMicro (58686)
AveMedia
averkey lite I work with xp ok.but I opperating vista now I cant on my tv screen.
Jan 09, 2008 | Avermedia QUICKPLAY (pquickplay)
AverKey3 Plus
Hi, sorry to tell you this, but static electricity has killed every conceivevable type of electronic device ever built by man or woman. The insides of your TV has very high voltage and the only safe solution is to take it to a repair man. Ask for a qoute before any work is done, try to get at least 2 quotes.
It may be cheaper to replace than repair the unit and with 2 quotes you will know that you are not being conned.
Regards mistyman
Oct 09, 2007 | Avermedia AVerKey Plus (AVERKEY-PC)
Monitor display not coming after some minutes
No it is your monitor after all you used your another monitor and all was well. For what its worth get another monitor. NOTHING ELSE IS WRONG!!!
Sep 29, 2007 | Compaq Presario 5000 PC Desktop
Avermedia QUICKPLAY (pquickplay) Logo
735 people viewed this question
Top Avermedia Televison & Video Experts
Joe Negus
Joe Negus
Steve Allison
Steve Allison
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
