Question about Tascam 2488 Portastudio Multitrack Recorder System
On the Tascam 2488 Digital Portastudio, how do you activate the Compression on just one (1) track? The way I'm doing it now, it's either "on" or "off" and it compresses ALL tracks.
  • gpucheu Apr 22, 2009
    Thanks for the quick response. Not sure I understand completely, but will print out answer and try later.
    Scholar:
  • 65 Answers
Press micx4 key then select key of the imput track
this will show the mic effect screen
press select or input key for the track or input channel to assign the mic effect
the mic effect screen for the channel appears
press yes/enter
the mic effect library opens
use left/right key to toggle between factory presets user presets or save preset
use the dial to select the effect you want to load
press yes/enter
Posted on Apr 28, 2009
  • Tascam Master
  • 19,396 Answers
You need to select the single track, and then associate to the effect, probably you are sending the whole channel to effect or
1. Press SINGLE to pull up the effect window.
2. Press ENTER in this window to see a list of effect
programs you can choose from. Use the DATA
WHEEL to scroll through the programs and press
ENTER to choose one.
3. Press the SELECT button above one of your
tracks, then press SEND (to the right of the
STEREO fader.)
4. Use the CURSOR buttons to select the Loop
Level and turn the DATA WHEEL to increase
the amount of signal being sent to the effect.
You can also send the channel to Effect 1 and
Effect 2 if you have external effects processors you
can connect to these outputs.
You can also add different effects or multieffect in the same way (eg. flanger-compressor to get an Eddy Van-Halen guitar style).
Posted on Apr 22, 2009
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Error code 3
Straight out of a Tascam 2488 manual...
When editing tracks, you have selected the
same track as both source and destination
for a duplicate operation.
Press EXIT and try again.
Jan 20, 2011 | Tascam 2488 Portastudio Multitrack...
Recently purchased the Tascam 2488 Neo Digital/Microphone Effects
Assuming you have your mic plugged in properly and all is working well save for this one issue, do as follows: press the SELECT button on the track/channel which has the mic on it. Then press the SEND button over to the right of all the tracks. The button is right under the EQ button. After you press the SEND button, a screen opens up and you can send reverb to that channel/track...as much as you want. I hope this helps.
Feb 17, 2010 | Tascam 2488 Portastudio Multitrack...
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Sonic maximizer
To use the maximizer as a send effect, connect the effect send (1 or 2) to the input on your maximizer, then connect the output from your maximizer back into any input A thru G on your 2488. You then assign the track you want to maximize to the correct send (1 or 2) using the send key and then assign the input to a track to record to.
To use a maximizer as an input effect (assuming guitar) simply plug yoiur guitar into the maximizer and then patch the maximizer to input H (Hi Z input of the front panel of the 2488). Assign input H to a track to record and this will record the maximized input signal.
Jan 03, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Hello
http://tascam.com/details;8,16,5,19.html
That is the link to download the manual in pdf format.
Oct 27, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
52 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
